I cannot install my Asrock Intel Arc A380 Challenger ITX 6G OC graphics card in my DeskMeet X300 equipped with a Ryzen 5 3600 CPU.
I get error code 8.
The drivers come from the Intel site.
Not having a gpu integrated into my CPU, I have to proceed with the installation with another graphics card connected in my PCI slot.
Hello Ehul,
Thank you for posting on the Intel️® communities. I am sorry to hear that you are experiencing issues updating your graphics driver for the Intel Arc A380. We appreciate your patience.
- Does the issue persist if you install the Asrock driver?
- What installation steps are you following? Are you using the Intel® Driver & Support Assistant?
- Provide us with a screenshot of the error message you receive.
- Create a report using the Intel
System Support Utility (Intel SSU). - Download the Intel SSU
- Open the application and click "Scan" to see the system and device information. By default, Intel
SSU will take you to the "Summary View." - Click on the menu where it says: "Summary" to change it to "Detailed View."
- To save your scan: click "Next"; then "Save
Jean O.
Hello Ehul,
I hope you are doing fine.
Jean O.
Hello Ehul,
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
