Intel® ARC™ Graphics
2459 Discussions
Intel Arc A530M in Lenovo LOQ 15IAX9I for PES 2021 reads badly
ilhamZamzami
Hello, here I am using an Intel Arc Graphic a530m, specifically as in the picture below. There is a problem when you want to play PES 2021 (E Football Pes 2021) the GPU indicates bad, is there a solution that can be provided? Thank You
ShunMnzed
@ilhamZamzami
The suitability of the Intel Arc A530M GPU for running "Football PES 2021" (E Football Pes 2021) depends on several factors, including the game's system requirements and the performance capabilities of the GPU itself. The Intel Arc A530M GPU is an entry-level to mid-range graphics card designed for mainstream computing tasks and light gaming. It may struggle with more demanding games at higher settings and resolutions due to its performance limitations compared to higher-tier GPUs.
Have you tried adjusting the graphics settings within PES 2021? Sometimes lowering the graphics settings can improve performance on certain hardware configurations. I see that you're still using 31.0.101.4679 GPU version, which is older version. Have you tried the latest drivers installed for your Intel Arc Graphics A530M? Sometimes, updating to the latest driver version can resolve compatibility issues with specific games.
Hope it work. thanks
Tyler,
Adlizers
i have same issue for this game, just pop up white screen and force close
