Intel® ARC™ Graphics
2769 Discussions
Intel Arc A770 FPS Performance Days Gone
addelucas123
New Contributor II
Good afternoon
Congratulations on releasing the latest Intel Arc A770 drivers. The problem I have with Days Gone is the camps and it drops 43 to 46 FPS at night in the six camps there are. The graphics reached 90 to 120 FPS, and I need you to continue reporting. performance drop from FPS 43 to 46 FPS at night on Intel Arc A770 days gone in very high settings, I'll send you the images and I need a response as soon as possible
Labels (2)
addelucas123
New Contributor II
20240421_173441 (1).jpg20240421_173457 (1).jpg20240421_173514 (1).jpg20240421_173547 (1).jpg20240421_173604 (1).jpg20240421_173628 (1).jpg
addelucas123
New Contributor II
Here you have the images of the camp where it drops at night from 43 to 46 FPS with very high settings and if I move away from the camp it reaches 90 to 120 FPS. During the day the performance also drops where the camp is from 43 to 46 FPS. I need you to continue correcting Days Gone FPS performance drop for Intel Arc A770 graphics card
ACarmona_Intel
Hello Addelucas123,
Goodafternoon.
To confirm, does the issue happen with the latest driver, 31.0.101.5445?
And also, please generate an SSU report to help us further analyze important details on your system, such as the OS build number, graphics driver version, errors logged in the system, etc. To generate the SSU report, please refer to the article: How to get the Intel® System Support Utility Logs on Windows. Please send us the generated SSU.txt file.
We look forward to your response!
Carmona A.
addelucas123
New Contributor II
Good morning
It has improved, but the area where the FPS performance of days gone drops the most is at night and there are five camp areas and I need you to improve to less than 10% or 15% performance, there is a drop from 43 to 120 FPS, with very high settings, That is to say, the areas that I am going to send you are the one that drops the most and the other drops but weakly 45 to 50 FPS. I need more drivers to improve days gone, tell the engineers that it has improved but not enough unless it is Note the performance or change should be 10% or 15% performance, and I have the latest drivers, 31.0.101.5445
(Virus scan in progress ...)
addelucas123
New Contributor II
good morning
Remember, even if you update the computer's bios, it will not improve performance at all. It is the drivers that Intel launches that improve the drivers, which is why I am telling you so that you keep it in mind, you must improve more performance days gone by using drivers to less 10% or 15% so that it is noticeable, then you must optimize the curve a little better when it reaches 74 or 75 degrees it should be running 2250 2300 RPM, any games
ACarmona_Intel
Hello Addelucas123,
Goodmorning.
Highly noted, we have our new release driver, which is 31.0.101.5518. Please try it and observe if it will enhance your Arc graphics performance; if not, please let me know so I can raise the case with our engineers so they can investigate the issue thoroughly.
Carmona A.
addelucas123
New Contributor II
Yesterday I thought about it and nothing, Persiste low fps of performance , there is zone that falls 43 to 120 FPS , please get serious with these drivers , improve DirectX 11 and the Days Gone, perfectly reach me 43 to 120 FPS both day and night and what I told you the camps, and answer before possible
addelucas123
New Contributor II
I tried this version of drivers 31.0.101.5518 and nothing persists, it jerks
ACarmona_Intel
Hello Addelucas123,
We are sorry for the delayed response.
Since the issue still persists after upgrading to driver version 31.0.101.5518, I will now escalate the case with our engineers so they can thoroughly investigate the issue.
I will post the response on this thread once I have the updates from them.
Thank you for your patience and understanding.
Carmona A.
addelucas123
New Contributor II
Good afternoon
Please be serious, I have been fighting with you to improve the performance of days gone from 43 to 120 FPS, for me it is little shame, I have to say it and recognize that you are not complying, 5% performance improvements days gone improve but not enough, Get serious about this, I like that game, And it's well optimized, The problem is not the game, it's the Intel Arc drivers, Please get serious, I'm tired of saying hey, do this, hey, do that, I think We are not a small child, Please take this very seriously, eee, And also take DirectX 11 very seriously in several general games, But be serious for God's sake, I have been with the graphics for 2 years or so, put it 1 and a half years, For this one Height should be more than surpassed, but that's not even it.
Greetings
ACarmona_Intel
Hello Addelucas123,
Thank you so much for patiently waiting on our response.
Please share with us your "SaveGames" folder so it will be easier for us to import the saved games and reproduce this issue.
The default location is "C:\Users\[%user_profile%]\AppData\Local\BendGame\Saved\%unique_user_ID%\ " Copy and zip the folder "SaveGames," then kindly share it with us.
By the way, please bear with us as we continue to enhance our Intel ARC graphics driver.
Carmona A.
addelucas123
New Contributor II
Good morning
It's just that we've been releasing drivers for years, and we're still at this point of not improving days gone by, it's just that I'm getting tired of telling you to improve and it's not worth 5% performance improvements, for a big change to be noticeable it's 15% to 20% performance, Please, get serious, Or I'm afraid I'll go back to the previous graph until a year or two years pass, you choose, And I'm going to be very hard on you, You should keep that in mind, And be careful, I'm paying attention not only days gone other games, Intel ARC A770 is superior to RTX 3060 TI, so you must comply, on the other hand you must comply yes or yes DirectX 12 at maximum performance, keep it in mind, I started it from scratch, I checked the files and nothing continues, but very low performance.
greetings
David
LilithTwilight
@addelucas123 wrote:
...Or I'm afraid I'll go back to the previous graph until a year or two years pass, you choose...
...oh yes, please go back to your previous graphic card and leave, would you please? ^^
ACarmona_Intel
Hello Addelucas123,
Good morning.
Thank you for providing us with the folder that we have requested.
We will now further investigate the issue and get back to you once we are done conducting the investigation.
Carmona A.
addelucas123
New Contributor II
I don't know any information about days gone, and I don't know where we've reached the agreement either, because the days gone is well optimized, please improve performance, tell the drivers engineers or driver developers that missing performance improvements Days Gone and more games, Intel Arc A770 should go 120 FPS in very high configuration 1920x1080 in days gone
ACarmona_Intel
Hello Addelucas123,
Thank you so much for patiently waiting on our response again.
We wanted to let you know that there is no ETA yet, and we cannot promise any particular outcome either as we are still investigating this report.
By the way, we will report back as soon as there is an update.
Thank you so much for your patience and understanding.
Carmona A.
addelucas123
New Contributor II
I don't care about Carmona, but the game days gone is well optimized, if you don't optimize drivers and improve performance it's not my problem, it's your problems, so I need you to improve as soon as possible
addelucas123
New Contributor II
Good afternoon, I wanted to know if they're going to fix the day gone performance issue using dirvers for Intel Arc graphics, or what happens because I don't have anything information.
ACarmona_Intel
 Hello Addelucas123,
We recommend that you update your graphics driver to 31.0.101.5594 since it seems that our engineers have already made improvements to the 31.0.101.5594 for the game days gone. If the issue still persists, please let me know.
By the way, we are truly sorry for the long wait, and we truly appreciate your patience.
Carmona A.
addelucas123
New Contributor II
Good afternoon, I'm going to send you a link and a well-explained video of the reason for the problem, etc. so you can see the performance, area of ​​the map, and there are more areas where the performance drops, than days gone, tell me if it's playable or not, for me, no, He also sends that to the engineers so that they can see it, and that they release the days gone drivers sometime to improve performance, I'll send you a link, I'm already tired of explanations, It is well explained, etc., all the camps that I see, performance drops, all of them, you can see it in the video, four camps that performance drops and there are more camps that performance drops.
https://youtu.be/1Cq2ZF21hXs
