Hello 薛某
请注意,我只能用英语为您提供支持。我使用网络翻译工具来翻译此回复,因此可能存在一些翻译不准确的情况。
Thank you for posting on the Intel® ARC™ Graphics Communites. I know that not being able to modify the behavior of the hotkey shortcuts for Arc Control can be problematic and interfere with other apps or games.
We want to let you know that we are working on this issue to add the function of modifying the shortcut behavior in the future. Please stay tuned to our Intel Newsroom for more information.
At the moment as a workaround, we advise that you end the Arc Control process through Task Manager when using an app in which the hotkeys cause interference.
Hugo O.
Hello 薛某
Please let us know if you have further concerns regarding the hotkey behavior of the Intel Arc Control Software. We would be glad to help.
Hugo O.
Hello 薛某
As explained in our previous post this behavior with the Arc Control Hoteys is expected and at the moment we recommend closing any application that causes interference when using the hotkeys as a workaround, however, rest assured this behavior is something we are working. We will now close this thread but you can open a new topic in case you have further questions.
Hugo O.
