Intel® ARC™ Graphics
3432 Discussions
Intel Arc750
ruanfferraz
Bom dia pessoal, estou com problemas no lumion 12 com a intel arc750, parece problema de drive
achei um outro tópico mencionando esse mesmo problema gostaria de saber se ja tem alguma solução para este caso
ID do bug 14019166699
Carlos_L_Intel
Hi @ruanfferraz
 Thank you for posting on the Intel® communities. I'm sorry for the inconvenience this might have caused you.
 Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool, hence; the translation may not be completely accurate.
 Let me check the information internally, and I will post back when I have more information.
Carlos L.
Carlos_L_Intel
Hi @ruanfferraz
 Thank you for your time. Verifying the information on this, there is no news yet to share about it, other than we are actively working on this issue.
 Do you have any other questions that I can assist you with, or is it ok to close this thread?
Carlos L.
Carlos_L_Intel
Hi @ruanfferraz,
Carlos L.
Carlos_L_Intel
Hi @ruanfferraz
Carlos L.
