Intel® ARC™ Graphics
3432 Discussions
Intel OneAPI based SYCL on Intel Arch A750
EminOzturk
Hi All,
       I am trying to run my SYCL code on Intel Arc A750 GPU. For some big size, I am getting the runtime error. I dont know why but max I can allocate 256MB on device's Memory. Is there any way to allocate more than that? Intel GPU has 8gb ram.
Emin
EminOzturk
Hi Hugo
    We solved this issue by activating resizable bar on BIOS settings.  https://game.intel.com/story/intel-arc-graphics-resizable-bar/
 Someone helped us on SYCL slack channel.  His answer was "The CPU can't address more than 256MB in one chunk when ReBAR is off, and Intel GPUs were designed to have ReBAR always on." So by changing BIOS setting of resizable bar to on It was fixed.
Hugo_Intel
Hello EminOzturk
Thank you for posting on the Intel® ARC™ Graphics. I am sorry to hear that you are experiencing issues on OneAPI when using your Intel® Arc™ A750 Graphics.
Please allow me to check this issue internally and I will post back once I have an update for you.
Hugo O.
EminOzturk
Hi Hugo
Hugo_Intel
Hello EminOzturk
We are glad to know you found a solution, thank you for taking the time to share this fix, and hopefully, it may help other community members experiencing similar behavior. Since the thread is now solved, we will proceed to close it. Please keep in mind that this thread will no longer be monitored by Intel.
Hugo O.
