Hello Rutkay,
Thanks for your patience. I understand that you requested to close this thread. Considering the issue, our engineers worked with the developers to address it. The issue you've reported has already been addressed in X-Plane 12 Beta version 12.1.0.
The update to the BETA version can be found here: https://www.x-plane.com/kb/using-x-plane-betas/
Please note that the fix is not available in the public version of X-Plane 12.
Installing the Intel® Arc™ & Iris® Xe Graphics - Windows* version 101.5186 or newer includes performance improvements for X-Plane 12.
You may download the driver at https://www.intel.com/content/www/us/en/download/785597/intel-arc-iris-xe-graphics-windows.html
Ernesto C.
Hello Ti1
Bitte beachten Sie, dass ich Sie nur auf Englisch unterstützen kann. Ich habe ein Web-Übersetzungstool verwendet, um diese Antwort zu übersetzen, daher kann es sein, dass die Übersetzung ungenau ist.
Thank you for posting on the Intel® ARC™ Graphics Communities.
This compatibility problem with X-Plane 12 is a known issue we are actively investigating and working on, at the moment there is no estimated time for the issue to be resolved but rest assured we continue to work on it.
Hugo O.
Hello Ti1
Please let us know if you ave further questions related to this topic or if you would like to close this thread.
Hugo O.
Hello Ti1
Thank you for letting us know. We will proceed to close the thread as per your request, please look forward to future driver updates that should fic this issue. Feel free to open a new topic if you need further assistance.
Hugo O.
Hello Rutkay,
Ernesto C.
Hello Rutkay,
Kindly advise if you still experience the issue after implementing the fix I've previously suggested.
Ernesto C.
Hello Rutkay,
This will be my last follow-up on this case. Since I haven't received any response from you, we'll go ahead and close this case. If you require assistance or have questions, please do not hesitate to contact us again.
Ernesto C.
