Intel® ARC™ Graphics
3294 Discussions
Low performance Grand Theft Auto V Enhanced PC
addelucas123
New Contributor II
Good afternoon, I have a problem with the performance GTA V Enhanced Intel Arc A770, The following happens the options that I put is not to say when you put everything to maximum the graphic options of the game with its ray tracing let's maximum that gives GTA V activated rescaling of amd fsr 3 I get 25 to 30 FPS 2560x1440p, And if I put 1920x1080p I get 60 to 70 FPS with everything maximum, I would like to inform you that I have all the drivers updated both the graph and the other drivers and the bios, the requirements that GTA V Enhanced asks I comply with it to spare, And it is more the Intel Arc A770 graphic to be 16GB of VRAM is the fast ones than the RTX 3060 but much faster, because nothing that walks me 25 to 30 FPS and I have all updated
1. Launcher Rockstar: Grand Theft Auto V Enhanced
2. Game graphics options: All to maximum the top graphics playing 2k, Includes Ray Tracing and Activated to Maximum
3. Graphics card model: Intel Arc A770 16GB LE Limited Edition
JedG_Intel
Hello addelucas123,
For me to address this properly, please share the information below.
1. Gather CapFrame data, please ensure that you play the game for at least 5 minutes
2. Please generate SSU Report
Jed G.
addelucas123
New Contributor II
Good morning, it cost me to get CapFrameX to be able to capture the game to see the performance behavior as you wanted or the Intel driver engineers, it goes from 20 to 27 FPS Grand Theft Auto V Enhanced PC with all graphic options to the maximum 2K without upscaling, I do not use upscaling because it does not have Intel XeSS technology, It only has AMD FSR 3 technology, What does that mean? That the Intel Arc A770 Limited Edition graphics card should go without upscaling playing 2K at 60 FPS straight, Why do I say that? Because the RTX 3060 pulls it, I've seen video with everything to maximum with RT activated 60 to 70 FPS 1080p, and I bet that the RTX 3060 1440p with upscaling I bet it pulls 60 FPS, It better be that my Intel Arc A770 LE Limited Edition graphics card runs like silk, that is to say at full 1080p above 100 FPS without upscaling and 2K 70 to 80 FPS and finally 4K there I get by but for having the 16GB of VRAM 45 FPS at least, and I'm talking to you with everyone at maximum with RT activated to maximum and that thing, because it seems absurd to me that a graphics card costs what it costs and does not give the performance that one wants, It pisses me off a lot, because it's the only game I play more often and the performance does not surpass the Intel Arc A770 to the RTX 3060, It's a shame to waste time and not be able to enjoy the things that have happened, I have been playing Grand Theft Auto V Enhanced PC for the longest time and the performance goes from 20 to 27 FPS, tell me what gameplay you see there? This Intel Arc A770 graphics card should perfectly surpass RTX 3060 and a little bit the RTX 4060, and it should also surpass Intel Arc A770 that I have seen on the internet that my Intel Arc A770 graphics card is at the same level as the AMD RX 6650 XT, Well now it's time to take a step forward, it surpasses RTX 3060, 3070 and a little bit the RTX 4060, and the Arc A770 graphics card should surpass RX6700 XT, Once it is get that performance, One says very well! , I also hope that with GTA 6 you pull it to the maximum eee activating with rescaler technology, Because it has so much Intel Arc A770 technology that it is losing everything it gives, if it is worth that Intel promises that DX12, Vulkan and that thing are better, Okay, so I did not fulfill it, And I want to take that into account, Now that Grand Theft Auto V Enhanced PC uses DX12 perfectly uses DX12, And in DX12 as you do not or superior engineers say that it performs well, it is better for the graphic, let it prove it surprise
greetings
David
CX_2025-03-05_09-32-04_Comparison.pngCX_2025-03-05_09-32-51_GTA5_Enhanced_.pngCX_2025-03-05_09-32-54_GTA5_Enhanced_.pngCX_2025-03-05_09-32-56_GTA5_Enhanced_.pngCX_2025-03-05_09-32-59_GTA5_Enhanced_.pngCX_2025-03-05_09-33-01_GTA5_Enhanced_.pngCX_2025-03-05_09-33-04_GTA5_Enhanced_.png
JedG_Intel
Hi addelucas123,
I understand that you have higher expectations for the Intel Arc A770, and I appreciate your perspective given that it has not met your expectations. For a thorough investigation, please provide the CapFrame data file instead of screenshots.
Additionally, could you inform us if there are any background applications running while you are playing the game? Are you observing high temperatures? It would also be helpful if you could share the power scheme you are using.
I hope to hear from you soon.
Jed G.
addelucas123
New Contributor II
Good morning, I don't have a background, and the temperature takes 74 to 75 degrees, as you said your 90 degrees is considered low is decor normal range, but it reaches 74 and 75 degrees Celsius, The only thing I play is 2560x1440 i.e. 2K at maximum graphics and RT activated at maximum
addelucas123
New Contributor II
but that you must comply, well the engineers if they comment that DX12 performs better Intel Arc A770 because it is not performing as it should be
addelucas123
New Contributor II
JedG_Intel
Hi addelucas123,
Thank you for your efforts. Upon reviewing the report, it appears that the gameplay duration was only 30 seconds. Kindly play the game for at least 2-5 minutes to allow for a proper analysis.
Jed G.
addelucas123
New Contributor II
Good morning, I'm going to send you a link that lasts 12 minutes recording gameplay, Why does the video last so long? Because there the video explained well, better said the ultra and high quality, even in no, I mean in the subject of ray tracing, let's say ray tracing, I need you to please improve the performance as soon as possible, Because removing ray tracing the Intel Arc A770 graphics card happy, but if you activate it the graphics card dies, That graphics card is designed to give it cane with its maximum power that it has and that graphics card, Intel Arc A770 is a range is not high-end, but it is mid-high, capable of moving perfectly at maximum at least above 60 FPS 2K, Why is that Intel Arc A770 graphics card enthusiastic, it is not 100% enthusiastic, whether it is high-end but it is a little high-end a little, that graphics card should be able to handle everything, let's say I bet that that Intel Arc A770 graphics card can surpass if you put the battery and improve your performance effort I bet whatever you want that it would even surpass the RTX 3070 reaching the same level as an RTX 3080, Because I have also seen that even in 4K 45 to 50 FPS I see it well, But the Intel Arc A770 can perfectly be at the same level as the RTX 3080, okay, it may see 1% less performance than the Intel Arc A770 comparing the RTX 3080 only 1%, okay but it is still at the level, And it can perfectly surpass the RX 6700 XT and RX 6750 XT, why do I say that the Intel Arc A770 surpasses it? Because having its 16GB of VRAM, memory width and higher TFLOPS, That Arc A770 graphic has to overcome that barrier , So I have no choice, that you put the battery, that you must breastfeed that graph either Intel Arc A and the B, I mean A770 or B580, both graph are able to overcome the graph majority, if we compare A770 vs B580, in specifications, arc A770 exceeds B580, for which I repeat. Grand Theft Auto V Enhanced that is serious with that problem, because I repeat arc a770 16gb le, you can put at the RTX 3080 entity 10 and 12GB, I know that this graphic RTX 3080 has greater nucelles of Cud It is almost at the level, and it really takes you, I am happy for now because the temperature 75 to 76 degrees with peaks 77 is improved, there is me, but well that we are doing, I need seriously please improve okay
https://youtu.be/9sHHZLWPyvc
https://www.youtube.com/watch?v=9sHHZLWPyvc&ab_channel=DavidPradosDeLucas
JedG_Intel
Hello addelucas123,
Thank you for your cooperation. This is really helpful for the investigation that I would conduct. I will get back to you to give an update as soon as possible.
Jed G.
addelucas123
New Contributor II
good morning, do the favor or tell the Intel driver engineers, to please improve the performance Grand Theft Auto V Enhanced and also the Indiana Jones and the big circle and crash that sends you, because I'm playing it and I need you to improve
addelucas123
New Contributor II
Good afternoon, is there any information on the performance of GTA V when everything is set to the maximum 2K?
Felipe_Intel
Hello addelucas123
This issue is currently under investigation. We'd appreciate your patience while we find the root cause and a possible solution for this issue. There is no ETA for this fix. As soon as I have news I'll be sharing them here.
addelucas123
New Contributor II
Good evening, I'm still waiting for the other comments about suggestions and other things. It's better to reply, please.
Felipe_Intel
The issue being investigated is the low performance in this game with A-Series cards. I'll share any news as soon as I have them.
About the mentioned "suggestions and other things", please list them below so I can try to provide my feedback about them individually.
