Intel® ARC™ Graphics
3285 Discussions
Marvel's Spider-Man 2 Subject Obsecured Bug
NAFIS007
In " Show Me The New York " mission the camera showing " Subject Obsecured ". I had tried low all of my settings as well as play it in windowed mode also reinstalled it and updated to the version 1.31. I also restarted, abandoned the mission similar time and now I am stuck kindly help me please.
Tasnimul
I have the same issue, and I have tried so many times. It does not work. I also asked some other Intel GPU users. They have the same problem. One says it has not happened in other GPUs.
ebrahimhossain
I'm facing the same problem, but my friend with an RTX card has no issues.
Lajos1
Én is ezzel küzdök! Ez driver hiba lesz akkor.
NAFIS007
Ok, guys I finally found a way to solve this. I have a save file it includes the game starting after when the photo has been clicked. Just download the save file from the given link below and copy all the save data inside of it then paste it in the following direction -
1. Documents > Marvel's Spider-Man 2 > A folder with random numbers > paste it in here
*** Remember to delete all the old save files in there ***
I got this from a trusted source and I tried it.
https://drive.google.com/file/d/1pWwknJ5yGbBXuYDuMxtzfckswseR5QJF/view
Tasnimul
hey @NAFIS007, didn't find any file's download link below
NAFIS007
I apologize for the mistake. However, I have attached the link. Kindly check it.
Tasnimul
Thnx man. It works perfectly. I was so frustrated and almost uninstalled the game too.
Mrfantastic
Brother you're a life saver still the problem is there can't do any photo missions hope intel fix this soon as possible
AliPenji
Thanks man.. you save us from hanging there. Its perfectly working..
DeancR_Intel
Hi NAFIS007,
Thank you for posting in the Community!
I would like to know if you still remember the graphics driver installed when the issue occurred. To better understand your system's configuration, I kindly request that you download the Intel® System Support Utility for Windows* software.
You can find the download link here:
  1. Download and launch SSU.exe.
  2. Check the box for "Everything."
  • When the scanning is complete, click "Next."
  • Click "Save."
Please send the saved file to us.
Hi Tasnimul, ebrahimhossain and Lajos1,
I appreciate your responses however to avoid further confusions, I suggest creating a new thread for this inquiry.
Dean R.
Lajos1
Nem jó az új driver. A control panel nem indul. Köszönjük a mentést!
Mu5tanG
@NAFIS007 man! you're a life saver thanks so much for the save file
DeancR_Intel
Hi NAFIS007,
Dean R.
DeancR_Intel
Hi NAFIS007,
Dean R.
