Intel® ARC™ Graphics
2870 Discussions
Minecraft causes confusing lag
Doomiiniikk
Intel Arc A750 8GB, Ryzen 7 5800X, 48 GB RAM. Hopefully enough info.
The weird thing happening is as such :
When minecraft runs in fullscreen mode I get noticable stuttering on the rest of my system.
When minecraft runs in windowed mode, it itself stutters intstead and the system runs fine but there's no in between. Symptoms persist if in main menu or in game.
Same symptoms with official minecraft launcher as with prism launcher, with or without fabric mod manager.
What context do you want me to share for further troubleshooting?
Aceitunator
The same happened to me a few months ago. Theres a workaround: go to the Intel Gaming Software --> Graphics --> Reset config, switch the 1st option to "Vsync off" (yeah ik... This sounds ridiculous). Reboot your system. In adition try to use a fabric modloader with Sodium + Sodium extras + Iris Shaders and set the cpu prerendered frame queue to at least 4 frames. It will make a huge difference with minimum fps too.
Bonus: Arc gpu drivers doesnt like overlays at all like the discords one btw it will ruin the overall performance adding stuttering. Disable everything and keep the gpu usage by other things / apps at minimum while playing (if youre using wallpaper engine just pause it etc). Looks like a scheduler or overhead issue but HAGS is still (arbitrary) capped for Alchemist gpus for some (comercial) reason hehehehe.
Anyway I hope this helps.
Doomiiniikk
I'm glad that I'm not the only one experiencing this issue.
I tried your suggested solution as written and I did not succeed in solving the issue.
As for the bonus point, overlays are not relevant to me as I have multiple displays connected and thus multitasking, media consumption alongside main task, is a priority. Meaning that  closing down everything else in the background is not a viable option for me either.
Also none of my system resources are nearly close enough to being overloaded which is why I don't understand the issue.
Aceitunator
Ooh, I see. Youre using a multiple display setup... Well, even with my workaround I can still manage to reproduce your issue... but even worse, when connecting my 2nd monitor that I usually use with my raspberry pi.
I said "even worse" because, at least for me, theres a system-wide stuttering even using the windowed mode but less than using the fullscreen mode so, yeah, you are not alone c':
Mike_Intel
Hello Doomiiniikk,
  1. Are you using an Intel brand Arc A750?
  2. Was it working fine before?
  3. Did you change any settings before the issue started?
  4. What are the troubleshooting steps that you tried so far?
@Aceitunator
If you need assistance, please create a new thread for us to assist you on your own thread and gather the details of your systems.
Michael L.
Doomiiniikk
Hello Michael!
1. I am using an intel brand A750, yes.
2. I have in the past while changed to a GTX 1080 so I am unsure of the time when this started. But I have a feeling of this having been an issue for quite a while, only the other day did I get fed up with it though.
3. I frequently change settings, be it ingame or elsewhere, so I cannot answer if and if so, what I changed in conjunction with realising the issue.
4. My troubleshooting steps are :
  Reinstalling Minecraft.
  Trying vanilla Minecraft.
  Trying Vulkan Mod (to no avail, fullscreen only shows black screen).
  Trying Sodium and similar performance mods.
  Reinstalling and updating drivers.
  Changing refresh rate for my monitors.
  Followed the steps in Aceitunators suggestions.
Monitoring task manager shows no sign of system overload, though it seems to get stuck at 32% in my case. The plateu in the 3D graph gets stuck at 32% when the game is in fullscreen and when a video is playing back on firefox.
Mike_Intel
Hello Doomiiniikk,
Thank you for the update.
Can you generate the SSU logs of your system for me to check it. Please refer to the link below on how to generate the logs:
Michael L.
Mike_Intel
Hello Doomiiniikk,
Michael L.
Doomiiniikk
Hi!
Sorry, I've been busy with some other things and forgot about this. I will try to gather the information and come back soon.
Thank you for notifying me.
Mike_Intel
Hello Doomiiniikk,
I will just wait for your next response on this thread.
Michael L.
Doomiiniikk
Alright so I've found some time to gather information.
I had in the meantime switched with a GTX 1080 from another system and used the A750 in there. R5 2600 + A750.
I did not recognize the symptoms on that system although the setups vary more than just the computer.
Below I attached the file from SSU.
Mike_Intel
Hello Doomiiniikk,
Did you generate the SSU in the R5 2600+A750 system?
Actually, I need the SSU logs of the affected system for me to investigate the issue.
If you have time, kindly install the A750 on the affected system then try to install the latest Graphics driver using DDU method.
It is possible that other graphics driver are still in the system, that also explains why there is no issue on the R5 2600 system.
Please refer to the link below for the steps of the DDU method:
https://www.intel.com/content/www/us/en/support/articles/000091878/graphics.html
https://www.intel.com/content/www/us/en/products/sku/227954/intel-arc-a750-graphics/downloads.html
Michael L.
Doomiiniikk
Hello.
The SSU logs is from them affected system, I have removed unwanted drivers and freshly installed the arc drivers before generating them.
Mike_Intel
Hello Doomiiniikk,
Thank you for the confirmation.
Have you tried installing the latest driver using DDU method to remove any remnants of the old drivers?
Michael L.
Doomiiniikk
Hello.
Yes I have done so standalone and in conjunction with the GPU switch.
I tried minecraft with the vulkanmod and the performance was outstanding.
Mike_Intel
Hello Doomiiniikk,
Let me clarify, does this mean that the issue is now fixed?
Michael L.
Doomiiniikk
There's one solution to the issue but I the core issue is still present.
The problem with the vulkanmod is that it's in BETA and isn't compatible with many other mods I use.
Mike_Intel
Hello Doomiiniikk,
Since the issue that you mentioned has compatibility issue. Please clarify if you need further assistance on this thread.
Michael L.
Mike_Intel
Hello Doomiiniikk,
Upon further checking this issue. Since you are using mods, we recommend that you should communicate with mod or emulator developer and ask them to submit a case directly in the Game Developer Program Forums:
Since you need to contact the other forums for this issue, I need to close this inquiry.
Michael L.
