My A750 8G has very low frame rates in Minecraft 1.12.2 modpack
only 1fps sometimes even 0fps
Hello @Dai_haoyuan
Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool, hence; the translation may not be completely accurate.
I am sorry to hear that you have problems with Intel® Arc™ A750 Graphics, and I’ll be more than happy to help you.
Was it working before?
Please use Display Driver Uninstaller (DDU), you will find the instructions there.
After that, please download and install the latest driver 31.0.101.4577
Also, in order to have more information about your system, please download, install and run Intel® System Support Utility for Windows. Make sure you check “Everything” before you scan, then save the report and attach it to your response.
Then, please generate and attach the Report for Intel® Intel Graphics Command Center
Jose B.
Hello Dai_haoyuan
We hope you are doing fine.
Were you able to check my previous recommendations?
Jose B.
Hello Dai_haoyuan
We hope you are having a nice day.
We have not heard back from you. So, we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jose B.
