My Arc a770 16gb reaches 80 degrees celcius playing red dead redemption 2 with high graphics and I am in a cold room and my pc is very well cooled.
- Tags:
- Temperature problem
I am the same as you in Red Dead Redemption 2, but worse the temperature rises 88 degrees, if I use DirectX 12 144Hz with vertical synchronization it throws me 1 FPS, I must put it at 50Hz and deactivate vertical synchronization, I must activate Vulkan to I'm doing well
Hello TheRitrax
Thank you for posting on the Intel® ARC™ Graphics. I am sorry you are experiencing high temperatures when playing Red Dead Redemption 2 on your system.
The temperature threshold for the GPU is 90C so everything under that max temperature should not cause any issue. Are you experience any type of crash as a result of this behavior?
You can follow these general steps to try lowering the temperatures.
Hugo O.
Hello TheRitrax
Were you able to check our previous post? Please let us know if you have further questions related to this topic.
Hugo O.
Hello TheRitrax
I hope you are doing fine.
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Hugo O.
