- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Hi ive recently upgraded from a gtx 1660 super 6gb to the intel arc a750. I only play one main game which is fortnite and I get very very poor performance to 120 fps (low setting performance mode) in some scenes where i usually had 250 with my other grafics card. Not only that, I get so many stutters when im playing causing the game to be unplayable. Ive tried everything and checked if I have everything coorect like the Risize bar one or the latest drivers and nothing still is having a very poor performnace. I have completely ruined my gaming experience due to this isue and i currently cant i even play.
I need to have help to optimize or get the same performance I had before.
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello Yagosanz,
Thank you for posting in our Community.
I would like to get more information about your system configuration because slow performance and stuttering may have different causes. Please run the Intel SSU tool (https://www.intel.com/content/www/us/en/download/18377/25293/intel-system-support-utility-for-windows.html?v=t) and share the results with me. This can help me compare with the data we have available for benchmarking.
I also suggest checking the article How to Improve Your Fortnite FPS on PC (https://www.intel.com/content/www/us/en/gaming/resources/how-to-improve-fps-in-fortnite.html) and see if there is any improvement.
Finally, the best performance on Fortnite is obtained by running the game in DirectX 12 mode so please give this a shot if not done it already.
Jay B.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi, I have tried with direx 12. With direx 12 I get less fps than I used to get with my other grafis card and performance mose. I need a way to still use the (Performance mode and get good fps without any lag spikes or low av fps).
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Also, the grafics card has an awfull coilwine which the other one didnt have
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Before a I had 300-600 fps on gtx 1660 (performance mode) No lag spikes
Now I have 120-250 fps Arc a750 (performance mode) with so many lag spikes its unplayable dropping to 1fps
Now I have 200-500 Arc a750 (Dirxex 12) some lag spikes
(I have a i5-12600kf overclocked to 4,9ghz, 16gb ram and ssd)
This has been a down grade and I also suffer from more input delay
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
If i dont get a solution to been able to run the game in (Performance mode) with no lag, I will just sell the grafics card and buy an rtx or gtx which dont suffer any of theese problems.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello Yagosanz,
We appreciate your feedback and we apologize for any inconvenience that this might have caused you. Please be informed that we are currently investigating this issue. To help us with the situation, we would like to confirm and request the following:
- Were you able to install the "High Resolution Textures" and "DirectX 12 Shaders"?
- I would like to follow up on our request using the Intel SSU tool https://www.intel.com/content/www/us/en/download/18377/25293/intel-system-support-utility-for-windows.html?v=t so I can help check your system info and assist us with troubleshooting.
- Also, can you try capture and share the performance data using CapFrameX? This is only optional but it can help us a lot in working on a solution for you.
Jay B.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello Yagosanz,
Were you able to check the previous post? Let us know if you still need assistance.
Jay B.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello Yagosanz,
I hope you are doing well. Since we have not heard any feedback regarding our previous post, we will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Jay B.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
what now Is there any way to improve it?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
[FIXED] Fortnite FPS, Stutter, Lag | Intel Arc GPU [Latest Driver + Mods]
Watch https://youtu.be/2_m44Gup2lk
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi there. I changed my settings to DirectX11 so far so good. Running 1440p on 120fps. All on Epic Settings.
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
