2.The audio keeps stuttering.
I am currently using the audio interface, but I have the same symptoms when I do not use it
(It is not a problem with the audio interface or other parts of the computer. Before replacing with arc, I used the same part and tried it on other computers, but I have to use X2-3 the normal buffer size
Surprisingly, all of these problems work fine just by turning off the Resizable Bar option.
Maybe it's a problem with PCIe or other options, so I've tried a lot of BIOS, audio environment, graphics options, and Windows options, but I can't find the answer anymore.
Please let me know if you have any idea or if you know how to solve this problem.
Once again say, I used the graphics driver has used all previous versions, current versions, and beta versions
BIOS audio windows have also been replaced and combined, but there is no solution at all.
Hello MSAPR,
Thank you for posting on the Intel️® communities. I am sorry to hear that you are experiencing issues with your ARC A770 16gbs. We appreciate your patience.
- What do you mean by saying that VR games are not played? Doesn't the game open?
- Are you getting any error messages when playing VR games?
- Do you experience any issues when you are at the STREAM VR?
- What VR headset are you using?
- Are you able to use the integrated GPU, and check if you can replicate the audio issue?
- What type of program causes the audio issue once you switch to them? Are they heavy-workload programs?
- Create a report using the Intel
System Support Utility (Intel SSU). - Download the Intel SSU
- Open the application and click "Scan" to see the system and device information. By default, Intel
SSU will take you to the "Summary View." - Click on the menu where it says: "Summary" to change it to "Detailed View."
- To save your scan: click "Next"; then "Save."
Jean O.
Hello MSAPR,
I hope you are doing fine.
Jean O.
Hello MSAPR,
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
Hello MSAPR,
Before we close this case, We would add that the Intel Arc graphics support for VR headsets continues to evolve as we ramp up our products and add updates to our software stack.
Best regards.
Jean O.
Hello MSAPR,
I will now close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
