Hello, I am an Intel ARC A750 Limited Edition user. When I try to log in to RDR2 normally on the desktop icon, I get an error ERR_GFX_STATE and the game does not open. When I log in from the Rockstar Games Launcher application, there is no problem, but when I try to log in from the desktop, I get this error.
@realburaaq , maybe you can try below step:
Go to advanced graphics settings in-game and put the renderer on DirectX12, apply settings and close the game.
After you closed the game go to the config file for your settings (it's in C:/Users/User/Documents/Rockstar Games/Red Dead Redemption 2/Settings and then system.xml, edit with notepad++)
Then find the following line called asyncComputeEnabled
Change the value from 'false' to 'true', then save.
Start up RDR2 and see if this fixed it.
Let us know if you managed to resolve it with the steps
my problem was solved it worked I followed the steps you wrote and my problem was solved thank you very much
