There seems to be issues resulted around me switching settings and ratcheting clank drift apart resulting in possibly running out of the vram issues. Requesting better memory management with that game be it an Intel driver or Sony related patch. To what I've been seeing, this issue seems to be occurring with all other graphics cards.
Hi DAHGames
Thank you for posting in the Community!
Please make sure you provide the following basic information when reporting a bug:
- What is the graphics driver you are using?
- Confirm you are using the latest WHQL graphics driver available (let us know the exact driver version you are using).
- A clean driver installation using DDU in safe mode is recommended. Follow this link for instructions.
- You could also test using the latest non-WHQL driver. This driver goes through all Intel quality assurance processes and is safe to use for evaluation.
- Tell us the name of the game or application and where to obtain it (Steam, Epic, etc.)
- Provide us with the Intel SSU report from your system.
- If you do not wish to submit the SSU report then at least provide us with the following information about your system:
- Processor make and model.
- Power Supply make and model.
- Motherboard make and model.
- Amount of memory (RAM).
- Operating System version/build number.
- Tell us the steps to reproduce the issue (this is very important!).
- For graphics corruption (per example artifacts, textures corruption or lighting glitches) please use Intel Arc Control to capture screenshots or a video showing the bug.
Dean R.
Hi DAHGames
Dean R.
Hi DAHGames
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Dean R.
