Hello!
ive been having a bit of an issue with trying to play FFXIV.
ive been having quite a lot of crashes and this error pops up.
My system is:
AMD Ryzen 5 7600X
Intel Arc B580 Challenger
32.0 GB Ram
Settings: High, 1080p.
I dont know what causes this issue but it shows up at random times
Hello MikoNii,
We are planning to replicate this. In the meantime, I would like you to perform a Clean Installation with the latest driver, 32.0.101.6449_101.6255 WHQL Certified, once installed, kindly let me know what would be the outcome.
Kindly let me know what would be the outcome.
Please answer the additional question:
- From what game platform are you playing Final Fantasy XIV?
I look forward to your reply!
Robbie R.
Hello MikoNii,
Thank you for reaching out and providing details about the crashes you're experiencing while playing Final Fantasy XIV. I understand how disruptive these crashes can be.
To further investigate, please answer the following questions:
- Are you running the game in Direct X 11, DirectX 12 or Vulkan?
- Does the crash happen during specific game actions?
- What is the platform you're playing the game on? (Steam, etc)
- Is Re-Bar enabled in the BIOS?
- Have you verified the integrity of the game files via your platform's launcher?
Please generate an SSU report to help me further analyze important details on your system. To generate the SSU report, please refer to the article: How to get the Intel® System Support Utility Logs on Windows*. Please send us the generated SSU.txt file.
I look forward to your response!
Robbie R.
Hello! i am running the game in DX_11 since this is the only option available
No, the game will randomly crashes. there's no specific game actions .
I am playing on the FFXIV standalone client.
Yes, the Re-bar is enabled in the BIOS
Yes i have! i also re-installed the game. did the DDU in safe mode, and re-installed the driver.
have also done the "fix problems using windows update".
the SSU text file has been attached as well
Hello MikoNii,
I will need some time to further investigate the issue. I will replicate this concern in our test lab and get back to you as soon as possible.
Randy T.
thank you!
looking forward to hearing the responses
Hello MikoNii,
Robbie R.
Hi!
i have done another DDU and performed a clean installation.
so far, no crashes yet, i did had to cap my fps to avoid some other issues i had.
I also ended up using DXVK for Final Fantasy XIV cause of some weird fps issues i had here and there with the B580.
I am playing Final Fantasy XIV on PC.
Hello MikoNii,
Thank you for sharing your update! It's great to hear that the clean installation has helped stabilize your gameplay.
I would like to know if you still need further assistance.
Robbie R.
Hi Robbie,
I believe i am good for now!
Thank you for your help
Hello MikoNii,
You are very much welcome! With that being said, I will now close this inquiry. If you need further assistance, please post a new question as this thread will no longer be monitored.
Robbie R.
