Hihi, I'm new here. I have a new Hp Pc with what looks like a special video card. I receive an update (Intel® Arc™ Graphics Windows* DCH driver) message from Intel Driver & Support Assisten (IDSA) that requires me to agree to remove the drivers installed by Hp. I have agreed to the update in consultation with HP. In short, the same update has already been installed (2x) on the PC and the PC has been restarted. Yet I am repeatedly or weekly offered the same update. Am I doing something wrong? What is this about?
Hello Soulaizza,
Thank you for posting on the Intel️® communities. I am sorry to hear that you are experiencing issues
The issue you report could be due to a clash with Windows* Update and will occur even if the driver is manually updated from Download Center or via Intel® DSA. For now, the only way to stop the update notification from Intel® DSA is to hide that particular update.
- What IDSA version you are using?
- Provide us with the Intel® DSA Folders, including them in a zip file.
- To gather information about your system, such as Operating System Built, Driver, and BIOS versions; please, create a report using the Intel
System Support Utility (Intel SSU). - Open the application and click "Scan" to see the system and device information. By default, Intel
SSU will take you to the "Summary View." - Click on the menu where it says: "Summary" to change it to "Detailed View."
- To save your scan: click "Next"; then "Save."
Jean O.
Hello Soulaizza,
I hope you are doing fine.
Jean O.
Hihi,,, Thank you for your patience...I was busy...In the attachments you will find requested files...I hope you can help me with this...Thanks in advance
Hello Soulaizza,
Thanks for the information provided.
We will look further into this scenario and provide a response at our earliest convenience.
Jean O.
Hello Soulaizza,
We appreciate your patience.
The Graphics team has split the integrated and discrete graphics drivers. If you are scanning now with the latest IDSA version v22.8.50, you shouldn't get an Intel Arc driver update offering anymore.
Please make sure you are using the latest IDSA version (found in settings), and also, refresh results on the IDSA scan page.
Jean O.
Hello Soulaizza,
Jean O.
