Resident Evil 4 Crashes during some cut scenes. It seems to be caused by the game's hair physics, because the moment I turned it off, the game ran smoothly almost immediately. The setting was set to Normal.
System:
i9 9900KF
Intel Arc A770 LE 16gb
64gb DDR4 3600mhz RAM
Asus Rog Strix Z390-F(ReBAR enabled)
Crucial 4tb NVME Solid State Drive
Windows 10 Home
The Fix:Disable Hair physics completely, or cut scenes will crash. Not sure if it's only my system though, as I know that Intel Arc doesn't support 9th gen CPUs officially.
Hello Carlos_C,
Thank you for posting back in the Intel Communities. We understand that experiencing crashing issues may be frustrating, and we will be more than glad to help you. To better assist you, please provide us with the following:
- When did the crashing issue start?
- Is Resizable BAR enabled in your system?
- Did you have another graphics card before you installed the Intel Arc graphics adapter?
- Which distribution service do you use to install the games? (Steam, Epic Games, Microsoft Store, Xbox Store)
- We would like to check if your system is up to date and look at further details about your system environment. Share with us a report using the Intel SSU:
- Open the application and click "Scan" to see the system and device information. By default, Intel
SSU will take you to the "Summary View." - Click on the menu where it says: "Summary" to change it to "Detailed View."
- To save your scan: click "Next" and then "Save.
Best regards
Jean O.
Hello Carlos_C,
We are checking on your thread to confirm if you have been able to gather the information we requested in our previous post. Note that the information is to better assist you.
Best regards
Jean O.
Hello Carlos_C,
Since we received a response from you with the information requested, we will proceed to close this thread. Note that the information would help us troubleshoot your issue more efficiently. In case you need additional information, please open a new question, as Intel will no longer monitor this thread.
Jean O.
Hello @Carlos_C,
Before we closed the thread, we went ahead and tested this game to see if we were able to replicate your problem. After testing the game, we were unable to reproduce the issue. We played the game without any crashes, everything went smoothly. We used the latest driver version 31.0.101.4900, so we suggest that you update your graphics driver as well. But before installing the new driver, it's essential to run the Display Driver Uninstaller (DDU) software. This will remove any previous driver files and leftovers that can affect your system's functionality.
We also want to share a video of our testing process in the lab. Please let us know if anything is missing that we should try. During our testing, we used Hair Strands settings on normal and high:
- Resident Evil 4 crashing test 4900 Hair Strands Normal
- Resident Evil 4 crashing test 4900 Hair Strands High
Best regards
Jean O.
Hello Jean and thank you for your response,
I used DDU to uninstall and install 31.0.101.4900 and while I had some stability at the start (albeit with a significant drop in frames) The game did not crash in the Main Story.
However, this is not the case with the "Separate Ways" DLC, as the game crashes after a few moments after the first cutscene. Just to make sure I reinstalled the game just to be certain that no files were corrupt and was working off a clean install. I was able to pinpoint one thing though: I can either have Ray Tracing on, or Have Hair Strand Physics on.
I think I can just chalk this one up to just not having a strong enough system, but just so I can make sure of one thing, can you ask the team to have the game's settings set to the Ray Tracing Preset with Hair strands On? just to be sure, because I replicated the test videos by making sure I picked the Balanced Preset and while I had some drops in performance, the game did not crash and then I alternated between Ray Tracing with hair strands off and Ray Tracing off with hair strands = High. Both worked, but Ray Tracing + Hair Strands caused the game to crash. One final point: It seems the crash tends to happen when there are multiple characters on screen with all their hair physics going. this is especially apparent in the Cabin Defense scene. Attached is my SSU report along with three test videos (All videos have the "Balanced" preset on)
Thank you for your time!
System:
CPU: Intel Core i9 9900KF (3.60ghz Base clock)
GPU: Intel Arc A770 LE 16gb (Driver version 31.0.101.4900)
Motherboard Vendor & BIOS Version: Asus Rog STRIX Z390-F, BIOS Version: 2004 (Resizable BAR enabled in BIOS)
Memory: 64gb DDR4 3600mhz RAM (XMP Enabled)
Operating System: Windows 11 Home 22H2
Resident Evil 4 Remake: Purchased via Steam
UPDATE:
As of driver version 31.0.101.4952, I no longer crash with both Ray Tracing and Hair Strands set to high.
Seems like whatever this driver did has fixed my issue. Thank you all for helping me troubleshoot.
Hello Carlos_C,
Thank you for the information provided. We are sorry for the delay in our response; it seems that there was a problem, and we were not able to see your response until now. Nevertheless, we are glad to know that the game does not crash with the new 31.0.101.4952. Hopefully, this information will help other community members, and you can finally play the game with no issues. Since the problem is now solved, we will proceed to close this thread.
If you need additional information or face any other issue, please open a new thread, as this one will no longer be monitored.
Best regards
Jean O.
