Intel® ARC™ Graphics
2897 Discussions
Star Wars Jedi : Fallen Order stuttering during gameplay
Warden002
Game is stuttering with a770 during game play, had an AMD card play this smoother with only 3Gb of ram. What would you need for logs to check it out?
Earl_Intel
Hi Warden002,
thank you for posting in the communities!
We are sorry to hear that you are having troubles on your system. To better assists you, could you provide us with the needed details listed below:
Is the game working fine before?
When did the issue occur?
What graphic driver version are you currently using?
Does the issue occur on the older graphic driver versions?
You can also try following the instructions on the link below:
Low Performance in Star Wars Jedi: Fallen Order* on Intel®...
Earl E.
NormanS_Intel
Hello Warden002,
I wanted to follow up to see if you had a chance to look over the information we posted. Your feedback at your earliest convenience would be greatly appreciated so we can move forward with resolving this matter.
Norman S.
RobbieR_Intel
Hello Warden002
We have not heard back from you so we will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Robbie R.
Warden002
To be honest I hadn't tried the game before on this PC and with an Arc A770. I did have it working on a 3Gb card a few years ago  however.
I tried as the article suggested and now the game is crashing.
I am currently using version 32.0.101.5972 of the driver. I have not tried on any other version of the driver.
