Intel® ARC™ Graphics
3469 Discussions
Unable to reach title screen in Indivisible (Arc A750)
OffToBattle
Using driver 31.0.101.5593 but prior attempts were on prior drivers. Game fails to get past initial loading screen, causing a lock that will not allow screen switching to Task Manager forcing a reboot to recover. I have encountered this on BOTH Steam and Xbox App/ Game Pass. So, I'm looking for advice about the issue and if I can do anything about it! Enclosing SSU data in text file.
Thanks for producing a really competitive graphics card and I hope to see it improve further.
s
RyanFeeko
New Contributor II
Hey @OffToBattle  just wondering if you managed to perform clean install driver. Below I shared the link on how to perform that.
https://www.intel.com/content/www/us/en/support/articles/000091878/graphics.html
Once clean removed, then reinstall the latest driver.
Hope this may helps...
OffToBattle
Sorry to take this long to get back to you, but it took me this long to get ahead on work schedule and make more thorough backups of that work before doing a full DDU uninstall using safe mode and all that. I had to do a subsequent Repair with normal Windows 10 to properly re-install Arc Control software.
At any rate, Indivisible failed to run, and since I encountered an identical loading screen permanent freeze, with at minimum Log Out required to exit the program (since I could not make Task Manager go on top over the game program). Since this is functionally identical to what I encountered previously with Steam on this card (Arc 750) I have no reason to doubt it's the same problem there too.
This brings me back to having no idea what is causing this or if anything can be done about it, and if the latter is the case then all I can do is hope the developers address whatever the problem is. If I want to play Indivisible I'd have to get it on console for the time being... but Arc 750 works great with a lot of things. Another game I've never managed anything with is Gundam G Generations Cross-Rays for whatever reason. I hear it works terribly on laptops with Intel architecture too...
