When I'm trying to open Epic Games Launcher after installing the launcher says "Unsupported Graphics Card. Please ensure your card meets the minimum system requirements....".
I have Intel ARC A750 GPU.
Hello tanim,
Thank you for posting on the Intel️® communities. We understand you are facing an error message when launching the Epic Game Launcher.
- Can you try reinstalling the program one more time?
- Is the Intel ARC A750 the first graphics card installed on your system?
- Create a report using the Intel
System Support Utility (Intel SSU): - Download the Intel SSU
- Open the application and click "Scan" to see the system and device information. By default, Intel
SSU will take you to the "Summary View." - Click on the menu where it says: "Summary" to change it to "Detailed View."
- To save your scan: click "Next"; then "Save."
Jean O.
Hello tanim,
We hope you are doing fine.
Jean O.
Hello tanim,
Best regards.
Jean O.
Hello tanim
Before closing the thread, we would like to make a last post informing you that we have tested our latest driver with Epic Launcher, and it worked correctly. In case the issue is still present, and since we don't have sufficient info to proceed further, you should contact the app developer for further support.
Best regards.
Jean O.
