Intel® ARC™ Graphics
2777 Discussions
Visual Artifacts/Flickering in the World of Tanks Garage caused by 'Lighting quality' settings
B580_WoT
These Artifacts only happen in the garage, nothing wrong in battle.
First used the driver gfx_win_101.6325_101.6252 (clean install with DDU), then gfx_win_101.6325_101.6253 when it was launched the same day (Friday).
Both versions have this issue. The intrgrated UHD 770 Grafiks work fine tho.
I then checked the in game settings and found out that by turning down 'Lighting quality' and turning off 'Post-prozessing' the Flickering stopped.
Specs:
CPU: I5 14500 with UHD 770 on B760 Chipset
RAM: 32 GB @4800
GPU: B580 12GB
PSU: 750W 80 Plus Gold / one 12V Rail with 20A max. (240W)
Monitor: 1080p@240Hz
Driver: gfx_win_101.6325_101.6252 and gfx_win_101.6325_101.6253
Windows:
 Edition Windows 11 Pro
 Version 23H2
 Build 22631.4602
(Virus scan in progress ...)
Earl_Intel
Hi B580_WoT,
For us to better assist you and determine the most appropriate resolution, could you please provide the needed details listed below:
  • May I know where you downloaded World of Tanks? is it on worldoftanks.com, Steam, wargaming.net, etc.
  • May I know if the game is working fine before?
  • Have you tried to roll back the graphics driver?
Once we have this information, we will be able to proceed with the next course of action and work towards resolving the issue you are facing.
Earl E.
B580_WoT
Hello Earl,
I downloaded the Wargaming . net Game Center from the website and installed WoT from there.
My previous system (I5-7600K + GTX1070 + WIN10 Pro) had no problem. I used the 1070 with my curred system (see above) untill 20.12. (Fr.), also without problems, then switch to the B580.
I first install the driver gfx_win_101.6325_101.6252, after using DDU to uninstall the Nvidia drivers, then launched WoT and had the problem seen in the video. Version 101.6253 didn't fix it. Do you want me to install 101.6252 again? Removing the curred driver with DDU first?
-B580_WoT
Earl_Intel
Hi B580_WoT,
Thank you for sharing this information with us, no worries, I will further investigate on this internally.
I will provide an update on this thread as soon as possible.
Earl E.
aux
Hey, I just installed my new Arc B580 card and I am experiencing the same issue. Had to time it correctly to get this screenshot, but you can see the blocks in the bottom left corner.
aux
Update: The issue seems to have been fixed now.
B580_WoT
The default garage changed with the end of the ingame event. Now, the artifacts happen in the onslaught garage (Video).
Driver: 32.0.101.6460_101.6259 (latest WHQL driver as well)
aux
You are right, my bad. Also happens in the normal garage now.
oelkersk
Same issue here, installed card last night, clean driver install. Artifacts in garage not in game play
