Intel® ARC™ Graphics
3325 Discussions
Was Starfield performance really fixed?
AjrAlves
New Contributor II
I'm seeing conflicting reports.
I have the gamepass version of the game, running with a 5700X, 32GB DDR4 3600MHz and a A750 (Drivers 4887/4900/4952 | Windows 10 64-bit 22H2 | ReBAR ON | PCI Express 4.0 x16 | Game on NVMe X4 SSD).
I noticed that performance outside the city is about twice as fast, but in the city I still get low GPU and ~20FPS, which is frustrating, since driver 4887 said it fixed Starfield performance.
ALSO: I have sometimes huge performance drops with ~50% GPU usage locked after loading new areas, but this gets fixed after a game restart.
Am i'm doing something wrong? Are you guys having better performance?
AjrAlves
New Contributor II
Up
Andres_Intel
Hello AjrAlves,
Thank you for posting on the Intel communities. I noticed that you are having low performance issues while playing Strafield with your Intel® Arc™ A750 Graphics, getting 20 FPS, I will be more than to help you.
First, I want to let you know that based on the release notes in driver version 4887, it says the game performance was improved for DirectX12 up to 117% uplift at 1080p with Ultra settings and up to 149% uplift at 1440p with High settings.
We still working really hard, to find the solution to this issue as soon as possible, I want to thank you for letting us know that you still having this issue.
Let me know if you have further questions.
Andres P.
Andres_Intel
Hello AjrAlves,
Since I have not received a response from you, we will continue with the investigation and as soon I have further information I will let you know
Andres P.
Andres_Intel
Hello AjrAlves,
Thank you for your time.
This week we released a new graphics driver, please clean install the graphics driver with Display Driver Uninstaller (DDU). For guidance, How to Use the Display Driver Uninstaller (DDU) to Uninstall an Intel® Graphics Driver. Then install the graphics driver version 31.0.101.4953.
If the issue persists, run and attach Intel® System Support Utility for Windows (SSU), you can find the steps on the link How to get the Intel® System Support Utility Logs on Windows.
Andres P.
Andres_Intel
Hello AjrAlves,
Were you able to update the graphics driver to version 31.0.101.4953? Did you see any difference?
Andres P.
Andres_Intel
Hello AjrAlves,
Andres P.
Andres_Intel
Hello AjrAlves,
Before closing this thread I want to let you know that this week we released a new graphics driver that includes a fix for this issue. Please follow the steps below and let me know the results:
Andres P.
Andres_Intel
Hello AjrAlves,
Were you able to install the graphics driver version 31.0.101.4972 to check if the behavior changes?
Andres P.
Andres_Intel
Hello AjrAlves,
Andres P.
