Intel® ARC™ Graphics
2608 Discussions
When will we see a solution to the constant ramping up and down on the fans ?
esarparn
When will we see a solution to the constant ramping up and down on the fans ? I have the Sparkle 750 titan and the fans are driving me crazy. I know that this is a well known issue with arc cards, i have 16 friends who have the same issue.
Quiet 3-6 seconds, then ramping up, going down 3-6 seconds and so on.
esarparn
I am about to switch out the card to a b580, but do the b580 have the same issue?
JeanetteC_Intel
Hello esarparn,
This issue is still currently being investigated. To further check, please share the details below:
1) Current graphics driver version.
2) Motherboard make and model and its BIOS version.
Or you may simply download the Intel® System Support Utility for Windows* software so I can check your system configuration. When the download is complete, launch SSU.exe.
  • Click Scan.
  • Click Save (.txt). Attach the log file as you reply.
I'll also check if there is reported or known issue with B5080.
I will wait for your reply.
JeanetteC.
esarparn
hello, i have a textfile for you with all information.
JeanetteC_Intel
Hello esarparn,
Thank you for sharing. I'll proceed on checking this issue internally and will post an update once available.
JeanetteC.
JeanetteC_Intel
Hello esarparn,
Good day!
I'm still currently checking on this and would need the following information from you:
  1. Can you still recall when this issue started?
  2. When does this behavior happen? Is it during processing high workload such as intense games or application processing? Does this behavior have a patterned time such only happening during boot cycle? Randomly Ramping up and down?
  3. Can you please share a video when the behavior starts?
I hope to hear from you soon.
JeanetteC.
esarparn
Unfortunately is my camera on the phone broken, so no video. The issue was from the very start, and it happens even in extremely light gaming and lighter applications.
The issue is that as soon as the card reaches 50 degrees Celsius, the fans start ramping up and as soon as the temp goes to 49 degrees they stop for about 3-5 seconds, long enough for the temp to reach 50 and so on...it's extremely annoying and not even custom fancurve helps.
JeanetteC_Intel
Hello esarparn,
Thank you for sharing this information. I truly appreciate your continued cooperation in sharing the details needed for further checking. I'll proceed with the investigation and will post an update once available.
JeanetteC.
