i can't get system to display on hdmi at all and i cant get 4k resolution on dp to hdmi cable ive tried multiple cables. system is a new build intel i7-12700kf 32 gb ddr5 arc a770 all on an asrock b760m steel legends mother board. any help would be greatly appreciated. A770 is on newest non-beta drivers.
Hello Nintairo,
Thank you for posting on the Intel️® communities. I am sorry to hear that you are experiencing issues
- Does the card use to work as expected before?
- Have you tried using different driver versions (previous and beta)?
- Are you able to try using another display device? This would help us identify if there is a compatibility issue with the card.
- Create a report using the following apps:
- Intel
System Support Utility (Intel SSU): - Download the Intel SSU
- Open the application and click on "Scan" to see the system and device information. By default, Intel
SSU will take you to the "Summary View." - Click on the menu where it says: "Summary" to change it to "Detailed View."
- To save your scan: click on "Next"; then "Save."
- Intel
- Intel® Graphics Command Center:
- Open the Intel Graphics Command Center
- Navigate to the Support tab
- Select System Diagnostic
- Click Generate Report
- Select Save and name the output file.
Jean O.
you do realize if theres no video we can't do any of this right?
Hello Nintairo,
I hope you are doing fine.
Jean O.
Hello Nintairo,
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
