Intel® ARC™ Graphics
2610 Discussions
cs2 fps 4/3 and 1080P
b580
Insufficient fps while playing cs2 game
The average fps I get while playing the game in 1980 resolution is 170-180 Low setting
The average fps I get while playing the game in 1024 resolution is 170-190 Low setting
Many people like me play the game in 4/3 resolution like cs2 and there is almost no fps difference, I was expecting the fps to increase when the resolution drops and I saw that I am not the only one experiencing this problem, there is another problem, there can be instant fps drops in the game, for example I see 230 but it drops to 110 fps. I am waiting for your help on this issue.
not: The FPS change is almost negligible at high and low settings. When I look at the bottleneck problem, I don't see a bottleneck because the graphics card usage is high and the processor is low.
bar is open
my pc
i5 14400f
32gb ram ddr5 5600hz
Intel B580
1TB M2 SSD
RobbieR_Intel
Hello b580,
Thank you for reaching out! I understand that you are encountering the frustration of not achieving the expected FPS when lowering your settings in CS2.
To better understand the issue being encountered, please answer the following questions:
  • What is the manufacturer of your Intel B580? (For example, Gunnir, Asrock, etc)
  • What is your current power plan?
  • Do you encounter this issue with FPS on other games?
  • Was the issue persistent from the previous drivers as well?
  • Does the FPS drop occur in specific scenarios or is it random?
  • If possible, can you provide a CapFrame X Log while playing the game? Please see ⁠Need help? Reporting a bug or issue with Arc GPU? for further instructions.
Please generate an SSU report to help me further analyze important details on your system. To generate the SSU report, please refer to the article: How to get the Intel® System Support Utility Logs on Windows*. Please send us the generated SSU.txt file.
I look forward to your response!
Robbie R.
b580
1. just intel no another
2.high performance
3. yes for example pubg and apex
4.I was still having issues with previous updates.
5. yes random
RobbieR_Intel
Hello b580,
Thank you for providing the requested information. I will now further investigate the issue being encountered. I will get back to you once I have an appropriate resolution.
I appreciate your patience and understanding.
Robbie R.
RobbieR_Intel
Hello b580,
Thank you for patiently waiting. I would like to inform you that we have reproduced the performance issue and is currently under investigation by our Driver Development Team. As soon as there is an update, we will let you know immediately.
Robbie R.
b580
I hope a solution emerges. I won't regret buying it
After doing some more research, I think the processor is causing a bottleneck. I hope this will go away with the new updates. Thank you for your help.
b580
is there no progress?
firot
Hey, for best performance in cs2:
On ingame settings choose prefer performance cores.
On bios disable hyper threading.
Disable steam overlay, discord overlay and any kind of background program that can use cpu.
I think those are the best settings and can have impact on your FPS.
Most games can use limited number of cores so you will never get full cpu usage and processors with high single thread performance will always have better performance. Even you are bottlenecked by your cpu you will never get %100 cpu usage because most of engines can't use all of your cores efficiently.
Felipe_Intel
Hello all, this is still under investigation. As soon as I have news, I'll be sharing them. We kindly appreciate your patience with this.
krillep
Hello. I have the same issue in CS2 as well, down to 80 FPS in some maps, consistently.
Just like b580 mentioned, I also have issues in PUBG, especially if I play in Borderless and with DirectX11 Enhanced enabled. As soon as I look towards any city in the game, whether I can see it or not, the FPS drops from 160-180 to 60 ish. Only way to remedy it, is playing the game in Fullscreen (and DX12), which gets pretty annoying with a multi monitor setup. Most solutions from searching have been tried, to no avail
Specs -
Motherboard: ASUS Rog Strix B550-F
CPU: AMD Ryzen 7 5800x
Memory: G.Skill TridentZ Neo 32GB DDR4 3600 MHz
NVMe: Sabrent Rocket 1TB PCIE4.
I have the Sparkle Arc B580 Titan OC Edition.
Last couple of driver updates have not resolved it.
