Hi There,
I hope someone will be able to help me.
I bought an Arc A770 GC but it crah when trying to start a game (fortnite, diablo 4, etc.). Computer just restart.
All was fine with my previous GC...I tried already to delete all previous drivers and install the new one but still not working.
Have run the system support utility, the log is attached.
Thanks for your help.
Hello saverock,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® Arc™ A770 Graphics.
Based on the Intel® Arc™ A-Series Graphics article, you may need the Resizable BAR or Smart Access Memory must be enabled for the card to work properly on your 3rd generation CPU (discountinued).
Article: https://www.intel.com/content/www/us/en/support/articles/000091128/graphics.html
This feature is available for the 10 generation or higher CPU. I recommend you to check with MSI to confirm if their motherboard supports Resizable BAR or Smart Access Memory or if it is compatible with the motherboard.
If MSI confirms that the board is compatible with these features, please let me know so can check this issue further.
Deivid A.
MSI confirmed the mothercard do not support this feature of resizable bar. Does it mean the graphic card is totally not compatible with it?
Hello saverock,
Thanks for your response. Before I confirm any compatibility issue, I would like to check the following:
1. Are you getting any error codes or bug IDs from the games when they crash?
2. Can you provide a list of the games affected?
Deivid A.
Hi Deivid A.,
1. I am not getting any error codes or ID because it is not only the game who crashed but the computer just turn off/on.
2. Basically it seems affecting all games who need some graphics : Diablo4, Fortnite, Wartales, Total war Warhammer3...not affecting fallout shelter for examle.
Thanks a lot,
Hello saverock,
Thanks for your response. In order to troubleshoot this issue, please try the following:
1. Install the latest Intel graphics drivers:
- Steps: https://www.intel.com/content/www/us/en/support/articles/000057389.html
- Drivers: https://www.intel.com/content/www/us/en/download/726609/intel-arc-iris-xe-graphics-whql-windows.html?
2. If possible, get in contact with MSI to get the steps to update your BIOS (V1.7):
Deivid A.
Hello saverock,
After checking your thread, I would like to know if you need further assistance.
If so, please let me know.
Deivid A.
Hello Deivid,
I have updated my bios and the drivers but it still does not work...I have also tried the beta driver for the graphic card but always same issue...
Best Regards
Hi Saverock
I had a similar issue to yourself in the past when I upgraded my graphics card (at the time I upgraded to an RTX 2080 super).
If I launched a graphically intensive game, my PC would just shut down soon after launching the game.
I found that my PSU wasn’t high enough wattage.
I upgraded to 850w PSU from 600w PSU and the issue stopped happening.
is your PSU up to the task of running your new Intel arc a770?
Hi Richieroo,
Thanks for trying to help me.
I just believe my PSU akasa 750W venow should be enought for the intel arc 770
Hello saverock,
Thanks for the confirmation. In order to investigate this issue I will need the following:
1. Provide a video where I can see the issue.
2. Provide any steps needed to replicate this issue.
3. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
- Download the Intel® SSU and save the application on your computer: https://www.intel.com/content/www/us/en/download/18377/intel-system-support-utility-for-windows.html
- Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
- To save your scan, click Next and click Save.
4. Provide the Report for Intel® Graphics Drivers:
Deivid A.
Hello saverock,
Deivid A.
Hello saverock,
Andres P.
Hello saverock,
Before we close this thread we want to let you know that we confirm our suspicion that the lack of Resizable BAR support on the motherboard side may be triggering the issues, best course of action would be to test the card on a different system that supports this requirement.
Let us know the results.
Andres P.
Hello saverock,
Thanks for your patience. I would like to let you know that Intel is investigating the issue with Diablo 4 since there are some reports about this game.
As soon as I have any details I will get back to you.
Deivid A.
Hello saverock,
Thanks for your patience. I am still investigating this issue with Diablo 4, to continue further I will need the exact game settings that you use that trigger the issue.
This will help me to replicate the issue.
Deivid A.
Hello saverock,
I am following up to confirm if you were able to get the exact game settings that you use that trigger the issue or if you need more time. You can take a picture of the settings.
Let me know if you need further help.
Deivid A.
Hello saverock,
I was checking your thread and see that we have not heard back from you.
I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
Deivid A.
