Hi mate i have today window's 23h22 installed but intel arc controll not installed because give me error and i go to driver website and i dont see window's 11 23h22 support can we get driver update to support windows 23h22
Hello ALAK,
Thank you for posting on the Intel
Just for you to know the reason shoul not be due to the Window 11 support since this software is supported by Windows 11 version 21H2 or higher. You can reveiwed the minimum requirements on How to Install Intel® Arc Control.
To better understand the issue, please answer the following questions:
- Take a screenshot of the error message.
- To help you checking if your system meet the minimum requirements, run, and attach the report for the following tool Intel® System Support Utility for Windows (SSU) to know yout system environment, you can find the steps on the link How to get the Intel® System Support Utility Logs on Windows.
Andres P.
Hello ALAK,
Were you able to run the Intel® SSU to check if you system meet the minimum requirements?
Andres P.
Hello ALAK,
Andres P.
