Hi Guys,
I installed Intel Advior Beta through OneAPI base ToolKit successfully. Our system is Ubuntu with Linux version 4.15.0. Our GPU is Intel(R) Gen9 HD Graphics NEO. I am using lastest sycl compiler with opencl backend. I want to collect GPU Roofline but it fails.
Here is my command:
advixe-cl --collect=roofline --profile-gpu --project-dir=./advixe --search-dir src:r=. -- ./myexe
Roofline would run analysis twice, survey analaysis and tripcount analysis respectively.
In first analysis, it reports GTPIN warnings as below. What is this?
advixe: Starting command line: advixe-cl --collect survey --profile-gpu --project-dir ./advixe --search-dir src:r=. -- ./myexe
Intel(R) Advisor Command Line Tool
Copyright (C) 2009-2020 Intel Corporation. All rights reserved.
advixe: Collection started. To stop the collection, either press CTRL-C or enter from another console window: advixe-cl -r advixe/e000/hs000 -command stop.
OCLC: Attempting to find device type gpu
OCLC: Successfully found OpenCL device
Device Name = Intel(R) Gen9 HD Graphics NEO
Build Options = -D data_t=float -cl-single-precision-constant
Build Options = -D data_t=double
Verification PASSED: 0 errors
advixe: Warning: [Instrumentation Engine]: GTPin: GTPin didn't find any kernels... Exiting without doing anything.
advixe: Collection stopped.
In second analysis, it reports device not found as below but obviously it successfully found the GPU device in survey analysis. How could this happen?
advixe: Starting command line: advixe-cl --collect tripcounts --profile-gpu --project-dir ./advixe --search-dir src:r=. --flop --no-trip-counts -- ./myexe
advixe: Opening result 25 % done
advixe: Executing query 100 % done
advixe: Executing query 0 % done
advixe: Executing query 114 % done
advixe: Collection started. To stop the collection, either press CTRL-C or enter from another console window: advixe-cl -r advixe/e000/trc000 -command stop.
OCLC ERROR(72): Unable to find device type gpu
terminate called after throwing an instance of 'std::runtime_error'
what(): OCLC ERROR(72): Unable to find device type gpu
advixe: Warning: The application returned a non-zero exit value.
advixe: Opening result 99 % done
Can anyone give me some help?
Hi Lin,
$ apt search ^intel-opencl$
Sorting... Done
Full Text Search... Done
I suggest you to install the compute-runtime packages from https://github.com/intel/compute-runtime/releases
BR,
Anton
Hi Lin,
Could you please run:
and copy the output here?
Also it would be helpful if you shared the OpenCL initialization part of your source code. You can contact me via corporate e-mail (Anton Timofeev) for it.
BR, Anton
Hi Anton,
I've sent you an email for detailed code. Here is the command output.
$ advixe-cl --version
Intel(R) Advisor 2021.1 beta07 (build 606302) Command Line Tool
$ dpcpp --version
Intel(R) oneAPI DPC++ Compiler 2021.1 (2020.x.0.0728)
Target: x86_64-unknown-linux-gnu
Thread model: posix
InstalledDir: /nfs/shm/proj/icl/cmplrarch/deploy_xmain/xmainefi2linux/20200728_000000/build/linux_prod/bin
Sorting... Done
Actually I found that the second issue is because I cannot collect tripcounts analysis on GPU. I trigger the tripcounts individually, it still reports GPU device not found error. That's so weird.
Lin
Hi Lin,
Sorting... Done
BR,
Anton
For more complete information about compiler optimizations, see our Optimization Notice.
