Intel® Aero Platform For UAVs
Peer-to-peer support only
This is a peer-to-peer only forum. This forum is not monitored by Intel.
776 Discussions
Additional R200 Realsense Camera
fjun
Hello
I tried to install an additional R200 realsense camera to my RTF via USB3.0 port.
(I used USB3.0 OTG connector to connect that.)
However, when I tried "cpp-muticam.cpp" example sample code, only the original R200 camera
can be detected.
https://github.com/IntelRealSense/librealsense/blob/master/examples/cpp-multicam.cpp librealsense/cpp-multicam.cpp at master · IntelRealSense/librealsense · GitHub
I have been checked the above example code works fine on my Ubuntu16.04 PC connected with two R200 camera via USB3.0 Hub.
Is there any limitation for using additional USB3.0 R200 camera with yacto OS layer on RTF?
Jun Furukawa
Community Manager
Hi JunFurukawa,
You should be able to connect the RealSense R200 camera to the USB3.0 OTG port on the Aero Compute board and run the cpp-multicam. I ran a quick test with and i was able to see both RealSense cameras with the cpp-multicam example.
Please note that a powered USB 3.0 hub is required for the RealSense cameras.
Jesus
fjun
Thank you for your reply.
I have been using USB3.0 HUB which can supply power up to 20W.
However, my additional R200 could not be recogonized with "cpp-multicam" example (on my RTF with firmware v1.5.1) .
Could you tell me what USB3.0 HUB you are using and what is your firmware version?
Best, Regards
Jun Furukawa
Community Manager
Hi Jun,
I am using an Anker hub that we purchased from Amazon. The Intel Aero is running image v1.5.1 with bios v01.00.13.I noticed some error messages when connecting the RealSense camera after the board boots. The messages went away when connecting the RealSense camera prior to powering the board.
There are some known issues with the RealSense camera not working correctly when using different cables and/or hubs. You can find RealSense reported bugs here: https://github.com/IntelRealSense/librealsense
Hope this helps!
Jesus
fjun
Hi
Thank you for your detailed suggestion.
We can buy Anker's hub also in Japan.
Therefore, I will retry after buying that.
Best Regards
Jun Furukawa.
Community Manager
Hi Jun,
Glad I can help. Let me know if you have any additional questions.
Jesus
