Intel® Aero Platform For UAVs
Peer-to-peer support only
This is a peer-to-peer only forum. This forum is not monitored by Intel.
774 Discussions
Aero RTF - Flight controller stops working
DFine
Hi
I recently bought the AERO RTF. I installed Ubuntu 16.04 and the last version of Ardocopter.
I managed to fly the drone a few times and run mavproxy (using tcp port 5760) and mission planner programs with no problem.
Today, after a good flight, I tried to run again but there were no heartbeat messages from the flight controller -
I couldn't get connection with the FCU no via Mavproxy and neither with Mission Planner.
Something seems to have gone wrong on the flight controller.
However I do manage to burn the firmware again but it does not help.
How can I check the FCU ?
Doron
Community Manager
Hello JustFineD,
Have you tried to connect to the Aero RTF Drone via QGroundControl? Do you see the same behavior when using px4 flight stack as ardupilot?
If you establish a communication via QGroundControla sensor calibration may be required. Also, which bios and FPGA version are you using?
Jesus
DFine
Hi Jesus,
I don't think that using QGC will improve the result - both QGC and MP are acts the same. They both waiting for a heartbeat signal from the FCU.
I will try to install the px4 and see if something will change.
Is there any script or (linux) tool to do some BIT test to the FC?
I tried to use the 'dmesg' command but not sure what I'm looking for...
BR,
Doron
Community Manager
Hi Doron,
It sounds like the flight controller is working as you are able to flash it. Please try to flash the FPGA again with aero-rtf.jam or aero-rtf-recovery.jam. The recovery will stop the flight controller on the bootloader, try to reflash the ardupilot or px4 flight stack.
Here are some steps:
https://github.com/intel-aero/meta-intel-aero/wiki/02-Initial-Setup# flashing-the-fpga
https://github.com/intel-aero/meta-intel-aero/wiki/02-Initial-Setup# flashing-the-flight-controller-rtf-only
Jesus
DFine
Hi Jesus,
I still do not get any signal from the flight controller even though I ran the following commands:
root@Aero-RTF1:/etc/fpga# jam -aprogram aero-rtf-recovery.jam
Jam STAPL Player Version 2.5 (20040526)
Copyright (C) 1997-2004 Altera Corporation
DONE
Exit code = 0... Success
root@Aero-RTF1:/etc/aerofc/ardupilot# aerofc-update.sh arducopter-aerofc-v1.px4
BIOS_VERSION = Aero-01.00.13
OS_VERSION = Ubuntu 16.04.3 LTS"
AIRMAP_VERSION = unknown
FPGA_VERSION = 0xc0
AeroFC firmware version = unknown
/dev/ttyS1:
Updating firmware on AeroFC
Erase : [====================] 100.0%
Program: [====================] 100.0%
Verify : [====================] 100.0%
Rebooting.
me@Aero-RTF1:~$ aero-get-version.py
/sys/firmware/dmi/tables/smbios_entry_point: Permission denied
/dev/mem: Permission denied
BIOS_VERSION = unknown
FPGA_VERSION = unknown
me@Aero-RTF1:~$ mavproxy.py --master=tcp:127.0.0.1:5760
WARNING: You should uninstall ModemManager as it conflicts with APM and Pixhawk
Connect tcp:127.0.0.1:5760 source_system=255
Log Directory:
Telemetry log: mav.tlog
Waiting for heartbeat from tcp:127.0.0.1:5760
Note that I switch to superuser for updates but the mavproxy.py I ran without su.
Does it matter?
Doron
DFine
Hi
I installed ubuntu and all the other programs (python, mavproxy, ...) and flash the FPGA and the arducopter.px4.
Only after I inserted the command: "sudo apt-get autoremove modemmanager" - the FCU back to life.
Doron Fine
DFine
Hi Jesus,
Unfortunately I was happy too soon. The FCU is unstable - sometimes it sends mavlink messages but most of the time does not.
Very weird the following sequence to receive message from FCU:
I first run: mavproxy.py --master=tcp:127.0.01:5760 - nothing happens
Then I run: mavproxy.py --master=/dev/ttyS1,115200 - still nothing happens
but at the third try when I run again mavproxy.py --master=tcp:127.0.01:5760 - I receive mavlink messages.
Where is the script that link the tcp port 5760 to ttyS1 ? I think the problems start there
BR.
Doron
Community Manager
Hi Doron,
The mavlink-router configuration file is located in the /etc/mavlink-router/main.conf. If you continue to have issues with the configuration, I suggest you to re-install Ubuntu and setup the Aero again.
Jesus
DFine
Hi Jesus,
I think i know what gone wrong:
The last time I wrote the parameters into the FCU (using MP) - I also wrote SERIAL* parameters that changed the baud rate between the AERO board and the FCU.
I edited the main.conf and changed there the baud rates - Now it seems to work just fine.
Doron
Community Manager
Great, I'm glad you figured it out!
Jesus
SBijj
Hello Doron,
Im running into the same problem. I connected to MP via telemetry radio and changed parameters which may have resulted in the FCU going dead. Could you please let me know how you changed the baud rates and the actual value of the rates.
Suraj
