An Aero Software Update to v1.6.1 has been added, updating the BIOS to v 1.00.16.
https://downloadcenter.intel.com/download/27399/Intel-Aero-Platform-for-UAVs-Installation-Files?prod... Download Intel® Aero Platform for UAVs Installation Files
Please also note the updated Wiki page in the "Initial Setup" section for instructions on how to remove v 1.00.13 and add v 1.00.16.
https://github.com/intel-aero/meta-intel-aero/wiki/02-Initial-Setup# flashing-the-bios Wiki link to flashing the BIOS for Yocto
https://github.com/intel-aero/meta-intel-aero/wiki/90-(References)-OS-user-Installation# bios Wiki link to flashing the BIOS for Ubuntu
Dear zack_intel,
where are we supposed to copy the aero-bios-01.00.16-r1.corei7_64.rpm file?
The wiki says "copy onto the Aero disk space." but that's a pretty vague explanation for such an important operation.
Thanks!
Hello Ludovico,
You can download the RPM file anywhere on the drone.
By default, it should go into the Downloads folder.
From there you can just navigate into the Downloads folder and depackage the file.
Note that on Ubuntu, it might not let you run RPM to depackage the file. You will need to install Alien and run these commands:
Installing an RPM file directlyIn a terminal, enter:
sudo alien -i package_file.rpmConverting the RPM file to a Debian packageIn a terminal, enter:
sudo alien package_file.rpmInstalling the converted Debian packageEither use http://packages.ubuntu.com/search?keywords=gdebi gdebi, or in a terminal, enter:
sudo dpkg -i package_file.debHope this helps.
Octavian
Hi Octavian,
I am trying to update the BIOS on Ubuntu but when I run the first or second Alien command provided I get the following error: "aero-bios-01.00.16-r1.corei7_64.rpm is for architecture corei7_64" ; the package cannot be built on this system. Before that error I get about 10 warning messages : warning: "aero-bios-01.00.16-r1.corei7_64.rpm: Header V4 RSA/SHA1 Signature, key ID bb0396db: NOKEY"
Thanks for the help,
Coline
Hello Coline,
Thank you for your message.
You need to modify the control file.
sudo alien -g package-name.rpm (this will generate a folder with the package contents) cd package-dir/ sudo vi debian/control
Now change the architecture (i386
in my case) to be the one you need. For example, I added the amd64
archicture and this is how the line ended up:
Architecture: i386, amd64
Last step:
sudo debian/rules binary
This will produce the .deb
file.
Don't worry about the NOKEY message. It's just looking for an RSA encryption on the file, if there's no encryption, you get that warning but it doesn't affect the output.
Hi Octavian,
Thanks for the answer. However I am still having issues. I followed the instructions but it doesn't look like I am getting the debian file (or I could be looking at the wrong place).
I did lscpu to figure out the architecture (x86_64), and I added it to the control file (see attached)
When I run "sudo debian/rules binary"
from the terminal in
the aero-bios-01.00.16 folder, I get the following output to the terminal
dh_testdir
dh_testdir
dh_testroot
dh_prep
dh_installdirs
dh_installdocs
dh_installchangelogs
find . -maxdepth 1 -mindepth 1 -not -name debian -print0 | \
xargs -0 -r -i cp -a {} debian/
dh_compress
dh_makeshlibs
dh_installdeb
dh_shlibdeps
dh_gencontrol
dh_md5sums
dh_builddeb
Where should the debian file be? I can't find it anywhere in the aero-bios-01.00.16 folder.
Thanks again for the help,
Coline
Hello Coline,
Thank you for your reply.
The architecture line in the Control file should like something like this:
Also, the .deb file should be generated outside of the folder where you run the command sudo debian/rules binary
If not, you can also run the command sudo alien -d package-name.rpm after modifying the control file.
If you are still having issues, please try the steps shown here: https://github.com/intel-aero/meta-intel-aero/wiki/90-(References)-OS-user-Installation# get-version 90 (References) OS user Installation · intel-aero/meta-intel-aero Wiki · GitHub
rpm2cpio aero-bios-01.00.16-r1.corei7_64.rpm | cpio -idmv
sudo mv BIOSUPDATE.fv /boot
sudo reboot
Hope this helps.
Octavian
Hi Octavian,
I have tried both methods, without success.
I added amd64 to the architecture list as you suggested which allows the debian file to be built with alien.
Then I did sudo dpkg -i aero-bios_01.00.16-1_amd64.deb
However the BIOS version staid the same after reboot.
Then I did:
cd etc/bios
sudo reboot
And the aero-get-version.py still returns Aero-01.00.13 for the BIOS_VERSION. Am I missing a step?
Thanks for the help
Hello Coline,
I think it's just the wrong folder.You have to put it in the "efi" folder
sudo cp /boot/BIOSUPDATE.fv /boot/efi/
For me that worked. After that it returns Aero-01.00.16.
Thanks a lot! it worked
The announcement has been updated to reflect the different installation instructions for the different OS options.
