Intel® Aero Platform For UAVs
Peer-to-peer support only
This is a peer-to-peer only forum. This forum is not monitored by Intel.
775 Discussions
Aero optical flow using down facing camera is not working
GWest4
I have gone through various forums configuring my Aero drone to use optical flow, but can't get it to work.
I have connected the LeddarOne sensor.
I have:
  • set EKF2_AID_MASK to 2 (use optical flow)
  • SYS_MC_ESG_GROUP to 1 (ekf2)
  • SENS_EN_LEDDAR1 to 1
  • Downloaded, compiled and ran the aero-optical-flow package. It seems to work and detect movement
  • QGroundControl>Widgets>MAVLink Inspector>OPTICAL_FLOW_RAD>quality is well above 100 (unless I put my hand in front of the camera)
  • QGroundControl>Widgets>MAVLink Inspector>DISTANCE_SENSOR>current_distance show the heigth above ground
BIOS_VERSION = Aero-01.00.16
OS_VERSION = Ubuntu 16.04.5 LTS"
AIRMAP_VERSION = unknown
FPGA_VERSION = 0xc2
AeroFC firmware version = 1.8.0
Moving the drone above the surface has no influence on LOCAL_POSITION_NED. However OPTICAL_FLOW_RAD does seem to change.
Now in a previous post, someone from Intel (Jesus) provided a test PX4-firmware (named "aerofc-v1_default_leddar_one.px4"), which I have tried, and it gives an improvement; LOCAL_POSITION_NED changes along with the movement of the drone.
However in our setup we also have a position estimate coming from triangualation (some indoor GPS sytem), which I feed to VISION_POSITION_ESTIMATE. In the default 1.8.0 PX4 firmware this is working, the values end up in LOCAL_POSITION_NED. But in the test PX4 firmware with optical flow working, the values from VISION_POSITION_ESTIMATE are no longer fused into LOCAL_POSITION_NED.
Of course I changed EKF2_AID_MASK to also incorporate vision positioning.
Any idea what changes are pending in the PX4 code to solve my issue?
Thanks and regards,
Gertjan Westeneng
Florinco B.V.
Community Manager
Hello gjwesteneng,
Thank you for your interest in the Intel Aero Ready to Fly drone.
Since you have already posted on https://communities.intel.com/thread/128475 https://communities.intel.com/thread/128475 could you please continue following that thread?
Thank you very much,
Eliza
Community Manager
Hello gjwesteneng,
Eliza
