Intel® Aero Platform For UAVs
Peer-to-peer support only
This is a peer-to-peer only forum. This forum is not monitored by Intel.
776 Discussions
BOTTOM CAMERA - RESOURCE BUSY
DMarc8
While my system is running the optical flow algorithm using the bottom camera and a LeddarOne, I would like to publish images from the bottom camera to ros topic for other purposes. I'm able to acquire images in ROS when the optical flow is disable, using the suggestions in If the optical flow is enable, when I launch the ROS application to acquire images, it exhibits an error saying:
Cannot open '/dev/video2': 16, Device or resource busy
Have anyone experienced this problem and solved it?
Thank you in advance,
Daniele
Community Manager
Hello daniele.marchetti,
Since you have another thread created for this matter, please add this information on https://communities.intel.com/thread/128475 https://communities.intel.com/thread/128475
Thank you,
Eliza
