Community
cancel
Showing results for
Search instead for
Did you mean:
MTrgi
BlueTooth is not working Yocto Intel AeroBoard
Dear all,
I would like to use Bluetooth to communicate with external devices, BLE should be available trough Intel Wireless 8260 chip. But it is not working in Yocto?
root@intel-aero:/lib/firmware# dmesg | egrep -i 'blue|firm'
[ 0.378627] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
[ 0.532133] Bluetooth: Core ver 2.21
[ 0.532161] Bluetooth: HCI device and connection manager initialized
[ 0.532168] Bluetooth: HCI socket layer initialized
[ 0.532174] Bluetooth: L2CAP socket layer initialized
[ 0.532189] Bluetooth: SCO socket layer initialized
[ 3.808363] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8000C-19.ucode failed with error -2
[ 3.808389] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8000C-18.ucode failed with error -2
[ 3.809097] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8000C-17.ucode failed with error -2
[ 3.832849] iwlwifi 0000:01:00.0: loaded firmware version 16.242414.0 op_mode iwlmvm
I described the situation also at:
https://github.com/intel-aero/meta-intel-aero/issues/361 Accessing BlueTooth on Intel AeroBoard · Issue # 361 · intel-aero/meta-intel-aero · GitHub
Where we can get the missing files? Or how to solve the situation. Thank you.
Community Manager
Hello trgiman,
Thank you for your interest in the Intel Aero Compute Board.
Can you please try the below commands?
  1. sudo systemctl enable bluetooth followed by reboot
After the board starts again, use:
  1. bluetoothctl
  2. agent KeyboardOnly
  3. default-agent
  4. power on
  5. scan on
Please provide me the outcome in case you receive any errors.
Eliza
MTrgi
Hi Eliza,
Output of bluetoothctl is always only:
Waiting to connect to bluetoothd...
Ok. Than I started bluetoothd directly from /usr/libexec/bluetooth
Now bluetoothctl returns [bluetooth] command line
But after trying your recommended commands or command list returns empty list and on your recommended commands it returns:
agent KeyBoardOnly
--> Agent registered
default-agent
--> Default agent request successful
power on
--> No default controller available
scan on
dmesg output changed a bit, but still driver errors?:
root@intel-aero:~# dmesg | egrep -i 'blue|firm'
[ 0.378385] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
[ 0.526271] Bluetooth: Core ver 2.21
[ 0.526299] Bluetooth: HCI device and connection manager initialized
[ 0.526307] Bluetooth: HCI socket layer initialized
[ 0.526312] Bluetooth: L2CAP socket layer initialized
[ 0.526328] Bluetooth: SCO socket layer initialized
[ 3.712095] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8000C-19.ucode failed with error -2
[ 3.712129] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8000C-18.ucode failed with error -2
[ 3.712149] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8000C-17.ucode failed with error -2
[ 3.746195] iwlwifi 0000:01:00.0: loaded firmware version 16.242414.0 op_mode iwlmvm
[ 918.482306] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 918.482318] Bluetooth: BNEP filters: protocol multicast
[ 918.482327] Bluetooth: BNEP socket layer initialized
Community Manager
Hello trgiman,
Thank you for your patience!
While the Intel Dual Band Wireless-AC 8260 has the capability, Bluetooth is not enabled for the Intel Aero platform. If Bluetooth is required for your project there are alternative interfaces for an add-on Bluetooth adapter.
Please let me know if I can help you with anything else!
Eliza
Community Manager
Hello trgiman,
Could you please let me know if I can help you with anything else?
Thank you,
Eliza
