Community
cancel
Showing results for
Search instead for
Did you mean:
ZChen57
Broke GPS and drone can not flight
Jump to solution
During my indoor tests with Intel Aero Drone, I broke the GPS rod and smashed the GPS and compass module. Now I just took the whole module off since I don't use it indoors. But I can not arm the rotors since the QGroudControl says preflight failed, no GPS and mag. So I was wondering how should I set the parameters for the flight controllers in QGC to unlock the GPS and compass, so I can still arm the drone without plugging in the GPS and compass module? Is there a way to keep my tests without plugging this GPS module? Thanks.
Eliza_D_Intel
Hello ZChen57, There is another thing you can try before purchasing another GPS module. If you set the parameter "ATT_W_MAG" to "0" it will avoid using the magnetometer. Unfortunately, if this will fail you will need to purchase another module and replace the broken one. Thank you and best regards, Eliza
Eliza_D_Intel
Hello ZChen57, Thank you for your interest in the Intel Aero Ready to Fly drone. The "COM_ARM_WO_GPS" parameter will allow you to arm the motors without the GPS module. For more information, please check: https://docs.px4.io/en/advanced_config/parameter_reference.html Thank you and best regards, Eliza
ZChen57
Hi Eliza, The issue is that I take off the GPS and compass module from the Intel Drone. The "COM_ARM_WO_GPS" parameter is not able to arm the motors since mag 0 is not found. Is there a way to arm the motors without this module? Thanks. *Best,* *Zhu Chen, graduate student.* *Department of Mechanical and Aerospace Engineering* *University at Buffalo, * *NY, 14261,* *(716)907-3904*
Eliza_D_Intel
