I am facing build error upon building Intel Aero image. Below is the procedure I followed.
repo init -u https://github.com/intel-aero/intel-aero-manifest.git -b master
repo sync
# Initialize build environment variables by running
export TEMPLATECONF=../meta-intel-aero/conf
source poky/oe-init-build-env
# Build intel-aero-image
bitbake intel-aero-image
Error thrown:
/home/ubuntu/intel_aero/build/tmp/work-shared/qemux86-64/kernel-source/fs/aufs/i_op.c:1393:15: error: 'generic_readlink' undeclared here (not in a function)
| .readlink = generic_readlink,
| /home/ubuntu/intel_aero/build/tmp/work-shared/qemux86-64/kernel-source/fs/aufs/i_op.c:1407:14: error: initialization from incompatible pointer type [-Werror=incompatible-pointer-types]
| .rename = aufs_rename,
| /home/ubuntu/intel_aero/build/tmp/work-shared/qemux86-64/kernel-source/fs/aufs/i_op.c:1407:14: note: (near initialization for 'aufs_iop[1].rename')
| cc1: some warnings being treated as errors
Please guide me what I am missing here.
Hello AdityaVarma,
Thanks for reaching out!
I will try to build Aero's BSP as it is explained in its wiki ( https://github.com/intel-aero/meta-intel-aero/wiki/Quickstart-Guide) and let you know if I'm able to replicate the issue.
Meanwhile, please provide us your environmental details in order to see if you are using the appropriate settings.
I'll get back to you here whenever I have any updates.
Pedro M.
Hi Pedro M,
I am trying build image for QEMU emulator(qemux86-64) on ubuntu 14.04 machine.
Thank you.
Hi AdityaVarma,
I just checked my build and I found out that it failed. I followed the same steps as you, nevertheless, I got a different error message:
ERROR: python3-setuptools-32.1.1-r0 do_packagedata_setscene: Error executing a python function in exec_python_func() autogenerated:
The stack trace of python calls that resulted in this exception/failure was:
File: 'exec_python_func() autogenerated', lineno: 2, function:
0001:
*** 0002:do_packagedata_setscene(d)
0003:
File: '/home/makers/Documents/Peter/intel_aero/poky/meta/classes/package.bbclass', lineno: 2168, function: do_packagedata_setscene
2164:do_packagedata[sstate-lockfile-shared] = "${PACKAGELOCK}"
2165:do_packagedata[stamp-extra-info] = "${MACHINE}"
2166:
2167:python do_packagedata_setscene () {
*** 2168: sstate_setscene(d)
2169:}
2170:addtask do_packagedata_setscene
2171:
2172:#
File: '/home/makers/Documents/Peter/intel_aero/poky/meta/classes/sstate.bbclass', lineno: 683, function: sstate_setscene
0679: break
0680:
0681:def sstate_setscene(d):
0682: shared_state = sstate_state_fromvars(d)
*** 0683: accelerate = sstate_installpkg(shared_state, d)
0684: if not accelerate:
0685: bb.fatal("No suitable staging package found")
0686:
0687:python sstate_task_prefunc () {
File: '/home/makers/Documents/Peter/intel_aero/poky/meta/classes/sstate.bbclass', lineno: 328, function: sstate_installpkg
0324: for f in (d.getVar('SSTATEPREINSTFUNCS') or '').split() + ['sstate_unpack_package']:
0325: # All hooks should run in the SSTATE_INSTDIR
0326: bb.build.exec_func(f, d, (sstateinst,))
0327:
*** 0328: return sstate_installpkgdir(ss, d)
0329:
0330:def sstate_installpkgdir(ss, d):
0331: import oe.path
0332: import subprocess
File: '/home/makers/Documents/Peter/intel_aero/poky/meta/classes/sstate.bbclass', lineno: 352, function: sstate_installpkgdir
0348: for state in ss['dirs']:
0349: if d.getVar('SSTATE_SKIP_CREATION') == '1':
0350: continue
0351: prepdir(state[1])
*** 0352: os.rename(sstateinst + state[0], state[1])
0353: sstate_install(ss, d)
0354:
0355: for plain in ss['plaindirs']:
0356: workdir = d.getVar('WORKDIR')
Exception: FileNotFoundError: [Errno 2] No such file or directory: '/home/makers/Documents/Peter/intel_aero/poky/build/tmp/work/corei7-64-poky-linux/python3-setuptools/32.1.1-r0/sstate-install-packagedata/pkgdata' -> '/home/makers/Documents/Peter/intel_aero/poky/build/tmp/work/corei7-64-poky-linux/python3-setuptools/32.1.1-r0/pkgdata'
WARNING: Logfile for failed setscene task is /home/makers/Documents/Peter/intel_aero/poky/build/tmp/work/corei7-64-poky-linux/python3-setuptools/32.1.1-r0/temp/log.do_packagedata_setscene.1990
WARNING: Setscene task (/home/makers/Documents/Peter/intel_aero/poky/meta/recipes-devtools/python/python3-setuptools_32.1.1.bb:do_packagedata_setscene) failed with exit code '1' - real task will be run instead
NOTE: Executing RunQueue Tasks
ERROR: python3-setuptools-32.1.1-r0 do_packagedata: Error executing a python function in exec_python_func() autogenerated:
0001:
*** 0002:sstate_task_postfunc(d)
0003:
File: '/home/makers/Documents/Peter/intel_aero/poky/meta/classes/sstate.bbclass', lineno: 708, function: sstate_task_postfunc
0704:
0705: sstateinst = d.getVar("SSTATE_INSTDIR")
0706: d.setVar('SSTATE_FIXMEDIR', shared_state['fixmedir'])
0707:
*** 0708: sstate_installpkgdir(shared_state, d)
0709:
0710: bb.utils.remove(d.getVar("SSTATE_BUILDDIR"), recurse=True)
0711:}
0712:sstate_task_postfunc[dirs] = "${WORKDIR}"
0350: continue
0354:
Exception: FileNotFoundError: [Errno 2] No such file or directory: '/home/makers/Documents/Peter/intel_aero/poky/build/tmp/work/corei7-64-poky-linux/python3-setuptools/32.1.1-r0/sstate-build-packagedata/pkgdata' -> '/home/makers/Documents/Peter/intel_aero/poky/build/tmp/work/corei7-64-poky-linux/python3-setuptools/32.1.1-r0/pkgdata'
ERROR: python3-setuptools-32.1.1-r0 do_packagedata: Function failed: sstate_task_postfunc
ERROR: Logfile of failure stored in: /home/makers/Documents/Peter/intel_aero/poky/build/tmp/work/corei7-64-poky-linux/python3-setuptools/32.1.1-r0/temp/log.do_packagedata.2003
ERROR: Task (/home/makers/Documents/Peter/intel_aero/poky/meta/recipes-devtools/python/python3-setuptools_32.1.1.bb:do_packagedata) failed with exit code '1'
NOTE: Tasks Summary: Attempted 5296 tasks of which 5291 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 3 ERROR messages shown, returning a non-zero exit code.
I will try to run some more tests in order to see what might be happening. I will update you here as soon as I have any useful updates.
Pedro M.
Hello AdityaVarma,
We have an update for your case.
We've been running some tests and with the latest BSP guide ( https://github.com/intel-aero/meta-intel-aero/wiki/Developing-on-Intel-Aero), we were able to successfully build Aero's image.
Please try this and let us know how it goes.
Pedro M.
Hello AdityaVarma,
Do you have any updates about this?
Pedro M.
