Community
cancel
Showing results for
Search instead for
Did you mean:
BPase
CAN Bus in the "Intel® Aero Compute Board Hardware Features and Usage Guide"
The block diagram shows both the CPU and fight controller having CAN connections to the I/O Expander.
The I/O expander lists only two CAN pins (presumably for the CPU).
Are the CAN buses actually connected? or does the flight controller have another way "out"?
70CPU_CAN_H72CPU_CAN_L
Jose_P_Intel
Hi intel386,
This is an interesting question! I will investigate more about the CAN connections in the I/O Expansion Connector and get back to you as soon as I have some useful information.
I appreciate your patience, have a nice day!
-Jose P.
BPase
Jose P.,
Any updates?
Bill
Community Manager
Hi Bill,
I apologize for the late reply, we are still investigating regarding the CAN connections in the I/O Expansion Connector.
We appreciate your patience, thanks for your understanding.
-Jose P.
BPase
Jose P.,
Any updates?
Bill
Community Manager
Hello Bill,
We are still investigating about the CAN connections, sorry for the inconvenience this may cause.
Thank you for your patience.
Have a nice day.
Andres V.
Community Manager
Hi Bill,
We apologize for the late reply.
We are working on improving our documentation. The Pins 70/72 are connected to the can bus controller on the compute board. Also, we have a wiki article on how to use it: https://github.com/intel-aero/meta-intel-aero/wiki/CAN-Controller CAN Controller · intel-aero/meta-intel-aero Wiki · GitHub .
-Jose P.
BPase
Thanks, but I know all that already. The original question was about the path out from the Flight Controller.
I.e.
"The block diagram shows both the CPU and fight controller having CAN connections to the I/O Expander.
Are the CAN buses actually connected? or does the flight controller have another way "out"?"
So, again, are they connected?
Bill
Community Manager
Hi Bill,
I'm sorry if I didn't make myself clear.
The CAN connections are connected directly to the CPU, we are working on improving this sort of diagrams on the Aero documentation.
We apologize for any inconvenience that this may cause.
-Jose P.
BPase
No Problem.
To Repeat then There is -one- CAN bus in the device used by both processors? COrrect?
Community Manager
Hi Bill,
Yes, there is only one CAN bus (CAN controller + CAN transceiver) but it is connected only to the Atom processor through the SPI interface on bus 1/chip select 0 (SPI1/CS0) and it can be accessed via spidev as /dev/spidev1.0 .
Have a nice day!
-Jose P.
BPase
See!!! That was easy!
Thanks again for taking the time to research this.
It helps,
Bill
Community Manager
Hi Bill,
We are here to help! Please let us know if any questions come up, we will be happy to help.
Have a great day!
-Jose P.
Jitendra_S_Intel
See if these links help:
/servlet/JiveServlet/download/453901-164636/Intel_Aero_Compute_Board_Hardware_Feature_Usage_v1.pdf https://communities.intel.com/servlet/JiveServlet/download/453901-164636/Intel_Aero_Compute_Board_Ha...
Per the 2nd link:
The Intel Aero Compute Board includes a http://ww1.microchip.com/downloads/en/DeviceDoc/21801G.pdf MCP2515 CAN controller and http://ww1.microchip.com/downloads/en/DeviceDoc/20005167C.pdf MCP2562 CAN transceiver. The controller is connected to the Atom processor via the SPI interface on bus 1 (SPI1) chip select 0 (CS0). It can be accessed via spidev as /dev/spidev1.0
