Intel® Aero Platform For UAVs
Peer-to-peer support only
This is a peer-to-peer only forum. This forum is not monitored by Intel.
775 Discussions
Changing flight controller after Ubuntu installation on Intel Aero RTF drone
NM1
I have installed Ubuntu on the Intel Aero RTF following the instructions in the wiki. I was using the PX4 flight controller but now want to switch to Ardupilot. When running:
cd /etc/aerofc/ardupilot/
aerofc-update.sh arducopter-aerofc-v1.px4
I get the following:
Is there another way to flash the flight controller in Ubuntu?
NM1
Hi Jesus,
Thank you for your response. It worked this morning and I didn't change a thing. The only difference is that I tried flashing the px4 flight stack first.
-J
Community Manager
Hi johnmav,
That is very strange, do you get the same output if you try to flash the px4 flight stack instead of the Ardupilot? I just tested both with Ubuntu and I did not run into any issues.
It seems that the flight controller is failing to boot into the bootloader. Try to run the command with sudo aerofc-update.sh nuttx-aerofc-v1-default.px4 (or ardupilot). If that does not make a difference, make sure the flight controller is firmly attached to the Aero Compute Board.
Jesus
NM1
Hi Jesus,
-J
