Intel® Aero Platform For UAVs
Peer-to-peer support only
This is a peer-to-peer only forum. This forum is not monitored by Intel.
774 Discussions
Compiling C Files in Yocto
JDiam3
I'm trying to modify the "spi_xfer" executable. I assume it is compiled from this C program: https://github.com/intel-aero/sample-apps/blob/master/spidev-app/spi_xfer.c sample-apps/spi_xfer.c at master · intel-aero/sample-apps · GitHub. What is the path to these files on the compute board?
Community Manager
Hi, Jeffrey95
Thank you for contacting Intel Customer Support.
Please let me look into it and I will get back to you later.
Alexandra
Community Manager
Hi, Jeffrey95
spi_xfer.c is not included in the Aero image, only the binary is included on Aero. You would need to rebuild the binary with your modifications.
You can download and generate the image source code following the instructions here https://github.com/intel-aero/meta-intel-aero/wiki/96-(References)-Rebuild-Yocto# build https://github.com/intel-aero/meta-intel-aero/wiki/96-(References)-Rebuild-Yocto# build
Once that is build, you can copy the binary over to aero.
You can also try to compile directly on Aero but some dependency/tools may not be present.
Alexandra
