Intel® Aero Platform For UAVs
Peer-to-peer support only
This is a peer-to-peer only forum. This forum is not monitored by Intel.
775 Discussions
Complete power failure upon switch to position control mode
Community Manager
I have just come across seemingly major issue while working with the Ready-to-Fly. I am attempting to get the PX4 position control flight mode working on the RTF and it's causing an instantaneous power shutdown for the entire drone (not just the Aero Flight Controller, the entire system)!
For some context I am trying to use local_position_estimator app from PX4. Folks I have spoken to in other research groups have had continued problems with the ekf2 app on PX4 so I am trying a different route using local_position_estimator.
Here is my setup and workflow
Aero Compute Board:
- running Ubuntu 16.04
- setup as desktop workstation, i.e. props removed, wall power as opposed to battery, monitor+keyboard+mouse interface
Aero Flight Controller:
- running the px4 build that comes with the drone: /etc/aerofc/px4/nuttx-aerofc-v1-default.px4
- (note same result if I flash the most recent commit to master on https://github.com/PX4/Firmware https://github.com/PX4/Firmware)
Workflow:
1. From Aero Compute Board, access mavlink shell via Aero Compute Board
cd ~/Firmware/Tools
python mavlink_shell.py 0.0.0.0:14550
2. shutdown ekf2 and startup attitude_estimator_q and local_position_estimator
ekf2 stop
attitude_estimator_q start
local_position_estimator start
3. Manually arm quadrotor and attempt to switch to position control mode
RESULT:
+ The entire Intel RTF completely powers down almost instantaneously; not just AeroFC, the entire drone complete powers off!!.
+ I will note that it has just enough time to send a REJECT POSITION CONTROL message to QGroundControl.
+ This does NOT happen if the quad is NOT armed
While it might be easy to disregard this as a PX4 problem, I disagree. Whatever PX4 is doing, it shouldn't be able to cause a complete power failure for the Intel RTF platform. Furthermore I am using a "vanilla" version of PX4 so it's not doing anything exotic.
Community Manager
Even though I don't know the root cause of the power failure, it looks like I found a solution. Based on information found here: https://dev.px4.io/en/ros/external_position_estimation.html https://dev.px4.io/en/ros/external_position_estimation.html and using this file as a template: https://github.com/PX4/Firmware/blob/master/cmake/configs/nuttx_px4fmu-v2_lpe.cmake https://github.com/PX4/Firmware/blob/master/cmake/configs/nuttx_px4fmu-v2_lpe.cmake, I made a new cmake file specifically for local_position_estimator instead of ekf2. As far as I can tell the functional difference between my previous work flow and using the custom cmake file is the inclusion drivers/irlock in the cmake file.
When I flash the AeroFC with this new firmware, I am able to switch into position control without causing a power failure
Community Manager
