I'm following the instructions here: https://github.com/intel-aero/meta-intel-aero/wiki/90-(References)-OS-user-Installation 90 (References) OS user Installation · intel-aero/meta-intel-aero Wiki · GitHub to attempt to connect by drone (running ubuntu) to QGC on my laptop:
Get your laptop IP and run on Aero:
sudo mkdir /etc/mavlink-router/config.d
- create this file:
sudo gedit /etc/mavlink-router/config.d/qgc.conf
and fill it with:
[UdpEndpoint wifi] Mode = Normal Address =
- launch QGroundControl on your laptop. It should receive automatically the telemetry feed from the drone.
Both my drone and laptop are connected to the same wifi network and the qgc.conf file contains the proper IP address of my laptop. However, QGC on my laptop is not connecting to the drone. Any advice for diagnosing this problem?
Hi, Jeffrey95
Thank you for contacting Intel Customer Support.
What is the output of the get_aero_version.py command?
Also, can you try to disable the firewall on your computer? It might be blocking the connection between QGC and the Aero Drone.
Alexandra
BIOS_VERSION = Aero-01.00.13
OS_VERSION = Ubuntu 16.04.3 LTS"
AIRMAP_VERSION = unkown
FPGA_VERSION = 0xc2
AeroFC firmware version = unknown
There's no firewall on my computer. I had no problems running QGC when I was running yocto on the drone. This problem only occurred when I switched to ubuntu.
I've updated the FC firmware with the wiki instructions (although it took many attempts to do this successfully):
cd /etc/aerofc/px4/
sudo aerofc-update.sh nuttx-aerofc-v1-default.px4
However, even after flashing the PX4 firmware, "sudo aero-get-version.py" still shows an unknown AeroFC firmware version.
I can confirm that I'm booted with the proper ubuntu version: when I run "uname -a" I get "Linux my-drone 4.4.76-aero-1.2 # 1 ... "
Hi, Jeffrey95
Could you please check if the mavlink service is running?:
sudo systemctl status mavlink-router
Also, could you try restarting the service and provide us the status output:
sudo systemctl restart mavlink-router
Alexandra
Hi Alexandra,
In my case when I run:-
mavlink-router.service - MAVLink Router
Loaded: loaded (/lib/systemd/system/mavlink-router.service; enabled; vendor preset: enabled)
Active: inactive (dead) (Result: exit-code) since 火 2018-02-20 16:44:11 JST; 1min 40s ago
Process: 1080 ExecStartPre=/bin/bash -c echo 4 > /sys/class/tty/ttyS1/rx_trig_bytes (code=exited, status=1/FAILURE)
2月 20 16:44:11 smartdrone systemd[1]: Starting MAVLink Router...
2月 20 16:44:11 smartdrone bash[1080]: /bin/bash: /sys/class/tty/ttyS1/rx_trig_bytes: Permission denied
2月 20 16:44:11 smartdrone systemd[1]: mavlink-router.service: Control process exited, code=exited status=1
2月 20 16:44:11 smartdrone systemd[1]: Failed to start MAVLink Router.
2月 20 16:44:11 smartdrone systemd[1]: mavlink-router.service: Unit entered failed state.
2月 20 16:44:11 smartdrone systemd[1]: mavlink-router.service: Failed with result 'exit-code'.
2月 20 16:44:11 smartdrone systemd[1]: mavlink-router.service: Service hold-off time over, scheduling restart.
2月 20 16:44:11 smartdrone systemd[1]: Stopped MAVLink Router.
2月 20 16:44:11 smartdrone systemd[1]: mavlink-router.service: Start request repeated too quickly.
and When I run
Job for mavlink-router.service failed because the control process exited with error code. See "systemctl status mavlink-router.service" and "journalctl -xe" for details.
Hi Yograj,
Please make sure you are booting into the correct kernel. Could you share the output of command uname -a?
it should be Linux frelon 4.4.76-aero-1.2 # 1 SMP PREEMPT Mon Nov 6 19:42:57 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
Alexandra
Hi Alexandra,
Sorry for late reply. Here is the output of:-
command uname -a
Linux smartdrone 4.476-aero1.2 # 1 SMP PREEMPT Thu Dec 21 09:55:38 UTC 2017 x86_64 x86_64 86_64 GNU/Linux
Hello Yograj,
Thank you for your reply.
I would suggest you re-install the "aero-sytem" package using the instructions on our wiki: https://github.com/intel-aero/meta-intel-aero/wiki/90-(References)-OS-user-Installation or re-install Ubuntu.
There seems to be an issue with the mavlink-router configuration and should be working after the fresh install.
Hope this helps.
Octavian
