Community
cancel
Showing results for
Search instead for
Did you mean:
izak
Error /dev/sda while flashing Linux image
Hi !
I'm trying to flash the intel aero image on the RTF drone following the instructions on the intel-aero github. When I boot from the bootable USB key, it starts installing then I get the following error :
" Installing image on /dev/sda ...
Error : Error opening /dev/sda : No medium found "
Can you help me please ?!
Community Manager
Hello lliili,
Thank you for your interest in the Intel Aero Compute Board.
Can you please try to see if your Aero is detecting the USB drive and if so how the system is naming it. To do so, with the USB not connected, enter the command ls /dev and capture the output. Then connect your USB drive and enter again the command ls /dev, if the board is detecting it you should see one more result, if so, how is it called?
Let me know what output you receive.
Casandra
izak
Thanks for answering,
I get 3 more devices (sdb, sdb1, sdb2) when I connect the usb drive to the hub.
When I run "fdisk -l" I get the following :
Disk /dev/sdb : 3.8 GiB ...
Device Boot ... Size Id Type
/dev/sdb1 * 1.5G 0 Empty
/dev/sdb2 16.9M ef EFI (FAT-12/16/32)
izak
I have a little update :
I ran the "cat /proc/partitions" command, and there's no sda device showing up. However, when I plug the USB key and run the same command I see the USB key as sdb (+ sdb1 & sdb2), but again the sda is not showing up.
Community Manager
Hello lliili,
Could you please send me a print screen of this output?
It would be very helpful.
Thank you very much in advance,
Casandra
izak
This is what I get after I press "install" in the grub menu
This is an extract from the output of the fdisk -l command :
And this is the the output for the cat /proc/partitions command :
Thanks !!
Community Manager
Hello lliili,
I have done some research and all the information I found in regards to the error message:
Error : Error opening /dev/sda : No medium found " , suggests that there may be something wrong with your USB key.
Could you try creating a bootable image image with a different USB key?
Let me know if this works.
Casandra
izak
I am working with a 2.0 USB OTG hub. And for now, I have tried with a 2.0 and with a 3.0 USB key; both resulting in the same error.
I will try some diiferent USB keys and I'll let you know if it worked.
Thanks again !
Community Manager
Hello lliili,
I would advise, using an USB 3.0 OTG you can find information on this here: /message/536901# 536901 Announcement: USB 3.0 OTG cable on click.intel.com
Let me know, how it works with a different USB key. I hope it will be successful.
Thank you,
Casandra
izak
Thanks for te link, but can you please recommend me a 3.0 OTG Hub because I am using the "recommended method" ie keyboard + mouse + USB key (+HDMI).
Tnx in advance!
Community Manager
Hello lliili,
There are many USB hubs on the market from which to choose from, unfortunately, we cannot recommend one.
You can check the following thread to see what other users have used: https://communities.intel.com/message/449747# 449747 https://communities.intel.com/message/449747# 449747
Let me know if this helps.
Casandra
Community Manager
Hello lliili,
Can you please tell me, if there is anything else we can assist you with?
Was my advise helpful?
Casandra
izak
I haven't received the new cables yet. I'll keep you posted as soon as i get them.
Tnx !
Community Manager
Hello lliili,
Thank you for your reply, I will close this thread for now.
Once you get the new cables, if you run into any trouble, please let us know in the community.
Thank you,
Casandra
