Intel® Aero Platform For UAVs
Peer-to-peer support only
This is a peer-to-peer only forum. This forum is not monitored by Intel.
776 Discussions
Getting the realsense camera data over Mavros
AShir3
I am trying to get the intel realsense camera data over mavros for using on the ground station(laptop)
I was successful in getting the px4 messages over mavrso from Intel Aero using the command
``` roslaunch mavros px4.launch fcu_url:="[gcs_url]:5760@[fcu_url]:5760 ```
The topics get published over mavros from the fcu.
The next step I run the following command from the https://github.com/intel-aero/meta-intel-aero/wiki/05-Autonomous-drone-programming-with-ROS# launching documentation
```roslaunch realsense_camera r200_nodelet_multiple_cameras.launch```
I see the camera topics been published on the intel aero
But I cant see them over mavros on the groundcontrol station (laptop)
Please let me know how can I get the camera topics over mavros on the ground control station?
Intel aero Information
BIOS_VERSION = Aero-01.00.13
OS_VERSION = Ubuntu 16.04.4 LTS"
AIRMAP_VERSION = unknown
FPGA_VERSION = 0xc2
AeroFC firmware version = 1.6.5
Thanks in advance,
Aniket
Community Manager
Hi Aniket,
Thank you for your interest in the Intel Aero drone.
Please let me look into it and I will get back to you later.
Alexandra
Community Manager
Hi Aniket,
You may find the links below helpful:
https://github.com/intel-aero/meta-intel-aero/wiki/05-Autonomous-drone-programming-with-ROS# launching https://github.com/intel-aero/meta-intel-aero/wiki/05-Autonomous-drone-programming-with-ROS# launching
https://github.com/mavlink/mavros/issues/574 https://github.com/mavlink/mavros/issues/574
Could you also tell me what do you mean by "Please let me know how can I get the camera topics over mavros on the ground control station?"
Alexandra
AShir3
Hi Alexandra,
Thanks for pointing those two links out. I am following those for getting the video streams in qground control.
But I want to get those streams to be published as images in the image_raw or theora rostopics for the following reasons.
1) I would like to do some image processing on the ground control station
2) I would like those streams to be accessed over wifi by other robots as well.
I am able to access the mavros topics over on the ground control station once I connect to the intel drone hotspot.
Thus I thought it would be possible to achieve similar for the video stream as well either over mavros ( which probaly is not possible) or some other video pipeline compatible with ROS.
The application that I am trying to use this for is multi-robot exploration
Aniket
Community Manager
Hi Aniket,
You may find this helpful:
http://wiki.ros.org/realsense_camera
Alexandra
AShir3
Hi Alexandra,
I get the intel real sense cameras running locally on the intel aero RTF drone.
But I want to access those topics over wifi on the ground control station (like a desktop).
In addition to that, is there any way to get the bottom black and white camera feed as a sensor_msgs/Image over ROS as well.
Aniket
intel_corp
intel_admin
Community Manager
Hi Aniket,
Your first question is really specific to RealSense and ROS, so the RealSense community will be able to provide more detailed help and information.
Also, you can't get those streams due to a limitation:
https://github.com/intel-aero/meta-intel-aero/wiki/06-Cameras-and-Video# take-a-photo-with-the-black-and-white-camera https://github.com/intel-aero/meta-intel-aero/wiki/06-Cameras-and-Video# take-a-photo-with-the-black-and-white-camera
The link below might also be helpful:
https://github.com/intel-aero/meta-intel-aero/wiki/06-Cameras-and-Video# rtsp-streaming-with-the-camera-streaming-daemon https://github.com/intel-aero/meta-intel-aero/wiki/06-Cameras-and-Video# rtsp-streaming-with-the-camera-streaming-daemon
Alexandra
AShir3
Hi Alexandra,
Thanks for the above tip. I will post the message on the real sense community and see what they respond.
The bottom cameras are not VGA and also not v4l2 compatible thats why I cannot get the stream working in OpenCV as well.
Even this piece of code for launching the gst streamer as posted on the wiki fails to work.
https://github.com/intel-aero/meta-intel-aero/wiki/06-Cameras-and-Video# take-a-rgb-photo https://github.com/intel-aero/meta-intel-aero/wiki/06-Cameras-and-Video# take-a-rgb-photo
This is the specific line of code I am talking about
'''shell
sudo gst-launch-1.0 v4l2src device=/dev/video13 num-buffers=1 ! jpegenc ! filesink location="rs.jpg"'''
Aniket
intel_corp, intel_admin, realsense,
Community Manager
Hi Aniket,
I tested this and it worked.
Check with ls /dev/video* if the camera drivers are correctly installed.
Could you tell me what error are you getting when running this?:
Alexandra
