Intel® Aero Platform For UAVs
Peer-to-peer support only
This is a peer-to-peer only forum. This forum is not monitored by Intel.
776 Discussions
HDOP and VDOP value 100.0 while outdoors
DKuro1
I can't get the gps to lock, how do I know GPS is working properly?
Daniel
Community Manager
Hello Daniel,
Thank you for your interest in our Intel products.
It's hard to know which the root cause of the issue might be. Could you provide some additional information so that I can provide you a better assistance? Please let us know the following:
  1. Which firmware version are you using?
  2. When did you begin to notice this issue (out-of-box, after a firmware update, after a crash)?
Additionally, I recommend you to double check that the antenna is correctly positioned and the wire connections are properly connected.
I would suggest you re-flash the latest firmware version and make sure the BIOS, FPGA and Flight Controller are updated as well to the latest version: https://downloadcenter.intel.com/product/97178/Intel-Aero-Compute-Board
Hope this helps.
Octavian
DKuro1
Hi Octavian,
You actually just helped me out on the accelerometer problem haha
Thanks for that!
I reflashed the firmware an awful lot of times in order to solve that problem so I guess I have all the latest configs:
BIOS_VERSION = Aero-01.00.13
OS_VERSION = Poky Aero (Intel Aero linux distro) v1.6.1 (pyro)
AIRMAP_VERSION = 1.8
FPGA_VERSION = 0xc2
Aero FC Firmware Version = 3.5.3
  1. When did you begin to notice this issue (out-of-box, after a firmware update, after a crash)?
We did not test it out-of-the-box, so I wouldn't be able to answer that one. When we received it, we went straight to a manual flight test, in which we DID notice the drone was tilted when flying and would not respond to neither RTL or pos hold. Nevertheless, we continued trying to calibrate it via controller trims and eventually crashed the drone.
Is there any way to test antenna integrity? I'm quite sure both connections and antenna position are ok.
Thanks!
Community Manager
Hello Daniel,
You can quickly check if GPS coordinates are received by FC.
SSH to Aero shell.
Copy the mavlink_shell.py to /home/root
a. You can find mavlink_shell.py here at https://github.com/PX4/Firmware/tree/master/Tools
Then login into FC shell( nsh>) using the following command
a. ./mavlink_shell.py 0.0.0.0:14550
Run the FC shell command: listener vehicle_gps_position
It will show lat: lon: and other GPS parameters like hdop, vdop..etc.
Octavian
DKuro1
Hello Octavian,
Just ran the command and got this results:
nsh> listener vehicle_gps_position
TOPIC: vehicle_gps_position instance 0 # 1
timestamp: 224963876
lat: 0
lon: 0
alt: -17000
alt_ellipsoid: 0
s_variance_m_s: 135.6610
c_variance_rad: 3.1416
fix_type: 0
eph: 4294967.5000
epv: 3750032.5000
hdop: 99.9900
vdop: 99.9900
noise_per_ms: 94
jamming_indicator: 128
vel_m_s: 0.0000
vel_n_m_s: 0.0000
vel_e_m_s: 0.0000
vel_d_m_s: 0.0000
cog_rad: 0.0000
vel_ned_valid: False
time_utc_usec: 0
satellites_used: 0
Daniel
Community Manager
Hello Daniel,
Since the compass was calibrated it means the GPS should be connected. Please try to restart the GPS in the shell command line using these commands:
gps stop
gps start
Then run the command "gps status" and please provide us with the output of this command.
Also, please check if other gps devices are able to obtain signal at your location.
Octavian
DKuro1
This is the output, runned it twice just be sure. About GPS signal, my cellphone was able to detect about 7-8 satellites but the drone detected none...
Thanks again,
Daniel
Community Manager
Hello Daniel,
Are you having the same issue in Ardupilot? I know you said it worked normally there on the other thread. Is that the same case here or are you also having GPS issue in Ardupilot?
Octavian
DKuro1
Actually, yes... same problem.
I was trying to solve one problem at a time so at the time I thought I wasn't get any signal because I was indoors, but further testing showed me it was some kinda problem with the GPS itself
Daniel
Community Manager
Hello Daniel,
There must be something wrong with the GPS module itself. I would suggest you purchase a replacement.
Spare parts can be found here: http://shop.yuneecusa.com/Aero-Drone-GPS-compass-module http://shop.yuneecusa.com/Aero-Drone-GPS-compass-module
Octavian
DKuro1
Ugh, okay....
Thanks again!!
Daniel
