Community
cancel
Showing results for
Search instead for
Did you mean:
GEden1
How Can I Snap a Picture using the RGB Front Facing Camera from Command Line/Code?
So when I use the command:
sudo gst-launch-1.0 v4l2src device=/dev/video13 num-buffers=1 ! jpegenc ! filesink location="rs.jpg"
A picture is snapped, but the quality is strange. It is very dark and green. I'm not sure why. If I record a video, it comes out fine. Attached is an example of a picture snapped to explain. Any ideas how to fix this? I'm running Ubuntu 16.04.example.jpg
