Community
cancel
Showing results for
Search instead for
Did you mean:
ZChen57
How to avoid breaking propellers while flying inside the net?
Jump to solution
We installed a net cage and let the drone fly inside the net. Right now we are just doing some basic control. The drone will break the propellers when it lands since the drone is to heavy and the propellers can hit the bottom net and break.
How do you conduct your initial tests without breaking the parts? Do you fly the drone outside and land on ground? We can only fly the drone inside and the net cage seems not good.
Eliza_D_Intel
Hello ZChen57, Thank you for your interest in the Intel Aero Ready to Fly drone. Here is one way to keep your drone flying in a desired area inside, used by Aero users - https://www.youtube.com/watch?v=iysofezsteA They have attached a string to the bottom of the drone. Thank you and best regards, Eliza
Eliza_D_Intel
Eliza_D_Intel
Hello ZChen57, You can also check this tutorial from Instructables: https://www.instructables.com/id/Intel-Aero-Drone-Adding-Propeller-Guards/ Thank you and best regards, Eliza
