I am trying to run some image processing code on my drone and I am having difficulties installing the opencv2 and the pyrealsense modules ? I tried every installation tutorial online but nothing worked for me.
Thank you,
Abdullah Al Obaidi
Hi, abdullah96
I would suggest you to install Ubuntu to work with openCV and Pyrealsense. Pylibrealsense has not been tested with Yocto and is not developed by Intel. If you want to pursue using Yocto, you would need to rebuild the Aero image and add the openCV recipe. You can find the instructions to build the image on the wiki: https://github.com/intel-aero/meta-intel-aero/wiki/96-(References)-Rebuild-Yocto https://github.com/intel-aero/meta-intel-aero/wiki/96-(References)-Rebuild-Yocto
Alexandra
