Intel® Aero Platform For UAVs
Peer-to-peer support only
This is a peer-to-peer only forum. This forum is not monitored by Intel.
775 Discussions
Installation hiccup: Having problems making a full installation of all the Firmware for the Intel Aero RTF Drone using Ubuntu
AInte4
I am currently trying to make a full installation of Ubuntu OS on my Intel Aero RTF Drone but I am having some problems with some of the Firmware. I went through the Yocto installation with this guide
https://github.com/intel-aero/meta-intel-aero/wiki/02-Initial-Setup#flashing-the-flight-controller-r...
and had no problems, but when I tried to follow the Ubuntu one
https://github.com/intel-aero/meta-intel-aero/wiki/90-(References)-OS-user-Installation
I run into issues regarding the AIRMAP version and the AeroFC Firmware version as they appear as "Unknown" after i complete the installation. I am trying to install PX4 on the drone and this is the information i get after running "aero-get-version.py":
BIOS_VERSION = Aero-01.00.13
OS_VERSION = Ubuntu 16.04.5 LTS"
AIRMAP_VERSION = unknown
FPGA_VERSION = 0xc2
AeroFC firmware version = unknown
I hope someone can give me some guidance on how to solve this issue.
Thank you.
Alexandra_C_Intel
Hi AInte4, Thank you for your interest in the Intel Aero drone. Could you please tell me the output of "sudo aero-get-version.py"? Also, Airmap is not installed yet, version not reported is expected. Regards, Alexandra
AInte4
The output is the one i attached on the post:
FPGA_VERSION = 0xc2
Alexandra_C_Intel
Hi AInte4, You said you attached the output of "aero-get-version.py". The firmware should show up when you use "sudo". Did you use "sudo"? Regards, Alexandra
AInte4
Alexandra_C_Intel
Hi AInte4, What happened when you ran the command "sudo aerofc-update.sh nuttx-aerofc-v1-default.px4"? What was the output? Regards, Alexandra
AInte4
Hi again,
Thank you for the responses.
I've fixed the issue.
The "sudo aero-get-version.py" command now gives the following output:
FPGA_VERSION = 0xc2
AeroFC firmware version = 1.6.5
I fixed this issue by following the following link:
https://github.com/intel-aero/packages/issues/37
Thank you for your help :)
